Does anyone know if there's away to crossflash (eg. with BDR Flash tool) my Pioneer BDR PR1AME to Pioneer's old BDR PR1MC that can do quality checks on BD-R and BDXL media (only 100GB)? PR1AME uses the same platform (RS 8000), the hardware boards are identical (ONP 8324-A, DNP 2388-A). It even has the white 4-pin connector right of the SATA-connector and also the "OPARG" logo is on the front bezel. Any help kindly appreciated!
Crossflash BDR-PR1AME to BDR-PR1MC for quality checks
blackice
Re: Crossflash BDR-PR1AME to BDR-PR1MC for quality checks
I'm not aware of such possibility. If you want to do burn quality checks just buy a LGBH16NS40 or NS55 and flash it to WH16NS58 1.V5 from the MK firmware pack. Then you can do these checks with qpxtool or VPTools.blackice wrote: Sat Jun 07, 2025 5:29 pm Hi,
Naitsy
Hi
Did you ever try the crossflash yourself with the BDR Flash tool (or DVRTool) and get any success turning the PR1AME into a full PR1MC with working quality checks on BD-R / 100GB BDXL?
And if so (or even if you were just looking), where did you source the actual PR1MC firmware file from?Any details would be super helpful — thanks!
