Flashing firmware on a Mac for LibreDrive
bachelorbob
Re: Flashing firmware on a Mac for LibreDrive
Post by bachelorbob » Tue Jun 18, 2024 5:38 am
ARMiller wrote: Mon Jun 17, 2024 3:03 pm So the ASUS needs to be flashed to work on my iMac. All flashing firmware that can be found on the MakeMKV website is only suitable for Windows. I can't imagine I'm the only one with this problem? Is there no one who can explain to me how I can solve this problem?
Start reading from here:
viewtopic.php?f=19&t=21863&start=17
ARMiller
Post by ARMiller » Tue Jun 18, 2024 3:15 pm
Thanks everyone!
I successfully flashed my ASUS drive with my Home Cinema PC. This wasn't entirely easy either, but I finally succeeded. After this I connected my ASUS to my iMac again and I am now ripping the first UHD😊
oneirobot
Post by oneirobot » Sun Dec 01, 2024 1:02 am
Hey all,
Thank you for the hard work everyone has put into compiling this thread and the countless others, specifically the Ultimate UHD Drives Flashing Guide Updated 2024. I have a question that hopefully is an easy answer from someone who is more knowledgeable than I.
I purchased an LG BP50NB40 SVC: NB52 and am trying to get it to rip 4K discs. Since I have a Macbook (Pro 2023, in case it matters) I'm not able to use the nice GUI tool, so I'm trying to work it out in the terminal. I've been fairly successful to a point, getting as far as enabling LibreDrive as shown in MakeMKV (see image below post). I've ripped standard blue ray discs with no issues since I've messed around initially, so I'm thinking I didn't mess up too badly.
@Billycar11 summarized the sequence of firmware flashes that this particular drive (SVC NB52) needs in the following comment:viewtopic.php?p=122269&sid=c61a25d9ce2b ... 71#p122269
I'm stuck on the "BP50NB40-NB50-1.03MK with bootloader/full flash" step. It is hopefully as simple as a different phrase in the terminal command, but I've read through a lot of these threads and if it's in there, I overlooked it.
Can anyone here potentially help me out? I can provide further info as needed, just let me know.
MakeMKV drive properties:
https://imgur.com/ACpAGAb
MKV Maker
Post by MKV Maker » Sun Dec 01, 2024 1:09 am
oneirobot wrote: Sun Dec 01, 2024 1:02 am I purchased an LG BP50NB40 SVC: NB52 and am trying to get it to rip 4K discs. Since I have a Macbook (Pro 2023, in case it matters) I'm not able to use the nice GUI tool, so I'm trying to work it out in the terminal. I've been fairly successful to a point, getting as far as enabling LibreDrive as shown in MakeMKV (see image below post). I've ripped standard blue ray discs with no issues since I've messed around initially, so I'm thinking I didn't mess up too badly.
I use Macs exclusively and in this case Terminal to flash my LG drives used no longer and for sale actually. You likely read my post earlier i this thread. I explain the console method clearly as possible. If you did not find it then I hope it helps when you read it.
Post by dcoke22 » Sun Dec 01, 2024 7:38 am
oneirobot wrote: Sun Dec 01, 2024 1:02 am I'm stuck on the "BP50NB40-NB50-1.03MK with bootloader/full flash" step. It is hopefully as simple as a different phrase in the terminal command, but I've read through a lot of these threads and if it's in there, I overlooked it.
If you look at the Ultimate UHD Drives Flashing Guide, in the section titled "Recommended Firmware to flash for MakeMKV:" down at the bottom you'll see:
if using command line add "full" after rawflash
If you scroll back to this post in this thread and look at the help output of the sdftool command on a specific drive, you can see a mention of the 'full' flag (reproduced here):
MTK19xx firmware module v1.30
Commands:
  dump [auto|full|user]
  Dumps firmware image
    dump full      - dumps full rom image (if not disabled in firmware)
    dump user      - dumps non-volatile user data
    dump auto      - dumps full image if possible, user data otherwise
  rawflash [<flag>,<flag=value>,...]
    Sends the image and flashing flags to drive
    for flashing in self-update mode
  flags:
    main           - flashes main firmware (this is the default)
    full           - flashes boot loader and main firmware (Caution!!!)
    de             - sets DE byte in image
    enc            - encrypts firmware before sending to drive
    slim           - force USB slim drive handshake
So far, you've probably used the 'rawflash' command with either the 'main' or the 'enc' flag. To do the full boot loader flash, you have to use the 'full' flag with the rawflash command.
As with all firmware flashing, go slow and be sure before you do a command. :)
oneirobot
Post by oneirobot » Sun Dec 01, 2024 4:06 pm
Thank you both! I did slow down a bit and went back and saw the debug commands in the previous comments. I am happy to say I'm up and running and have now ripped a 4K BD with no issues! Appreciate the patience and assistance!
dcoke22 wrote: Sun Dec 01, 2024 7:38 am
Commands:
  flags:
MKV Maker wrote: Sun Dec 01, 2024 1:09 am
cincyguy
Post by cincyguy » Fri Apr 25, 2025 2:37 am
Hi all. I just purchased a Verbatim 43888 with the following showing up in MakeMKV:
Product: BD-RE BU40N
Revision: 1.05
Serial number: MOFOAME3340
Highest AACS version: 81
I have tried all the steps mentioned in this thread and I keep getting the following error: Drive "/IOBDServices/D5D25996" not found
Has anyone else had this problem? Apologies if this has already been handled it's my first time trying to flash a drive on Mac and I am finding it relatively difficult.
Post by dcoke22 » Fri Apr 25, 2025 1:02 pm
cincyguy wrote: Fri Apr 25, 2025 2:37 am Hi all. I just purchased a Verbatim 43888 with the following showing up in MakeMKV:
Revision: 1.05
What is the output from running step 6? When you run the command:
./makemkvcon f -l
you'll get the ID of your optical drive on your system. You then substitute this value into the command in Step 7.
fettesb
Post by fettesb » Sat May 10, 2025 2:15 pm
Hi, I also purchased a Verbatim 43888. MakeMKV showed me the following...
Laufwerksinformation
OS-Gerätename: /dev/rdisk4
Aktuelles Profil: BD-ROM
Produzent: HL-DT-ST
Produkt: BD-RE BU40N
Revision: 1.05
Serienummer: MO7P2DE4959
Firmware-Datum: 2124-04-23 13:47
Markierungen der Bus-Verschlüsselung: 17
./makemkvcon f -l
Found 1 drives(s)
00: /IOBDServices/18BCE9FC
HL-DT-ST_BD-RE_BU40N_1.05_212404231347_MO7P2DE4959
./makemkvcon f -d '/IOBDServices/18BCE9FC' -f /private/tmp/sdf.bin rawflash full -i /private/tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Reading input file /private/tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Flashing flags = 0x1 : 0 0 0 1 : ---- ---- ---- BOOT
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.05_212404231347_MO7P2DE4959
yes
100% Operation finished
Done successfully
when i open MakeMKV the Status is the same (Status: Possible, not yet enabled) and the revision is still 1.05
Please help :?
Post by dcoke22 » Sat May 10, 2025 2:30 pm
fettesb wrote: Sat May 10, 2025 2:15 pm Hi, I also purchased a Verbatim 43888. MakeMKV showed me the following...
Produzent: HL-DT-ST
Revision: 1.05
./makemkvcon f -l
Found 1 drives(s)
yes
Done successfully
Please help :?
I'm pretty sure the 1.05 firmware on your BU40N is encrypted… so you need to change 'rawflash full' to 'rawflash enc'.
Asumovieman
Post by Asumovieman » Wed Jun 04, 2025 10:41 pm
Please help me figure this out. I am new to all this and have never used terminal on a MAC but I am trying.
I tried following segfaulted post and just copy and pasting but it’s not working for me.
Could you walk me thru the very beginning with downloading the mikes firmware pack? I went here and download it…
https://www.makemkv.com/download/mk-fir ... 200720.zip
I downloaded it to my Mac desktop and unzipped it and found the BU40N N Main bin file. I placed it on my desktop.
Makemkv is installed in applications.
Then I followed the step by step directions but it’s not working. I probably do not have the bin in the proper spot? Any help for a true beginner?
bachelorbob
Post by bachelorbob » Sat Jun 07, 2025 10:19 am
Post by dcoke22 » Sun Jun 08, 2025 12:04 pm
Asumovieman wrote: Wed Jun 04, 2025 10:41 pm I tried following segfaulted post and just copy and pasting but it’s not working for me.
I presume this post from @segfaulted.
One can not just copy & paste those commands into Terminal to do the task. The same is true for the suggested reading from bachelorbob.
At a high level, one has to figure out the identifier of the optical drive. This is step 2 in @segfaulted's list or the './makemkvcon f --list' command from bachelorbob's suggested reading.
Once the drive identifier is discovered, it is used in the command to actually flash the drive along with the name and location of the firmware file you want to flash onto the drive.
Do you know what the identifier of your drive is?
MovieNut
Post by MovieNut » Sun Aug 17, 2025 1:45 am
Not sure if this is too obvious but I've been successful in using the GUI-based Flashtool on a Windows emulator (VMWare Fusion) in my case. Windows 11 seems to work (and is free).
Fusion is also currently free. I'm running on a Mac Mini M4 Pro - so no Intel processor required. If there's a separate thread already covering this let me know, otherwise we could start one if there's interest.
TheRealAlexDC
Post by TheRealAlexDC » Sun Sep 07, 2025 1:11 am
segfaulted wrote: Tue Jun 18, 2024 5:22 am
That should be it. See if the drive takes UHD discs after a reflash.
Hello, I have to thank you for this step by step. I was skeptical on ever doing this because aside from being new at this, I'm a Mac user and the Windows laptop I have barely has enough energy to boot up.
I got a Verbatim slip drive but MakeMKV recognized it as an LG BU40N.
Now to search the forum because I have been successful at ripping some but not all the UHD discs from the Skywalker Saga.
I'm very happy to start digitizing my Blu-ray collection, so thank you :)
