Rambo III errors
LtTyler5
Rambo III errors
Post by LtTyler5 » Fri Jun 06, 2025 3:03 pm
I've attempted to rip 2 different Rambo III blu-ray discs with no luck. I get these errors, but don't have these issues with other discs.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '20296237056'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '20399910912'
Error 'Posix error - Input/output error' occurred while reading '/dev/sr0' at offset '20399910912'
I've looked up the error before on MakeMKV forums but considering it litterly only happens with this movie is there soemthing else going on? I've ripped probably near 1k movies. I've only seen an issue with this and Stargate.
Re: Rambo III errors
Post by dcoke22 » Sun Jul 06, 2025 1:06 pm
The standard advice applies; gently clean the disc and try again.
Errors like this:
generally mean the optical drive was unable to correctly read a spot on the disc. Often, cleaning the disc can help. If you have an alternative drive, it is worth trying the disc in the other drive. In my experience, some drives just don't like some discs. If none of that helps, try an alternative copy of the disc.
Jimmers
Post by Jimmers » Tue Jan 06, 2026 8:26 am
I have the same problem. The disk plays in the Xbox One S blu ray player, but fails in 2 different LG units.
MakeMKV v1.18.2 win(x64-release) started
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS40 1.05 KL4M8B95323' at offset '24509874176'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS40 1.05 KL4M8B95323' at offset '24509937664'
udf: node fe/efe failed!
Using LibreDrive mode (v06.3 id=7FC45AF98B4B)
File 00008.mpls was added as title #0
File 00002.mpls was added as title #1
Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00005.m2ts has length of 23 seconds which is less than minimum title length of 60 seconds and was therefore skipped
File 00006.m2ts was added as title #2
Title #00007.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
File 00012.m2ts was added as title #3
File 00013.m2ts was added as title #4
Title #00008.m2ts has length of 45 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00009.m2ts has length of 43 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Saving 1 titles into directory D:/Video/RAMBO_III
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '24509937664'
