Yethidran
Post
by Yethidran » Thu Jun 05, 2025 6:15 pm
Billycar11 wrote: Thu Jun 05, 2025 2:44 am
Yethidran wrote: Thu Jun 05, 2025 12:42 am
i have too many drives... so getting confused with it all...
Hehehehe!!!!
Enable ask for single drive mode in makemkv looks like it's not from your pics
i tend to rip 4 to 6 different movies at the same time, so i guess single drive mode would not be an option for me..
Hehehehe!!!
Yethidran
Post
by Yethidran » Thu Jun 05, 2025 6:17 pm
i am using Windows 11 Pro with an, i9, 9900K gen processor..
still going strong and sturdy.
Post
by Billycar11 » Thu Jun 05, 2025 10:53 pm
Yethidran wrote: Thu Jun 05, 2025 6:15 pm
Hehehehe!!!!
Hehehehe!!!
Hhhhh it would help with that trust me
You would never get the drive interference I rip 12 at a time for testing drives I would know....
As 1 makemkv instance would only see 1 drive not hold everything up as it looks at each drive
Yethidran
Post
by Yethidran » Fri Jun 06, 2025 12:46 am
okie, thanks buddy. cheers!
sspell
Post
by sspell » Thu Sep 25, 2025 8:16 pm
Need help with flashing this drive to work with MKV UHD any help appreciated. I'm a noob at this ha!
Manufacturer: PIONEER
Product: BD-RW BDR-X12
Revision: 1.07
Serial number:
Firmware date: 2023-08-01
Highest AACS version: 77
Drive platform: Pioneer RS9000
Firmware version: ID56
Post
by MartyMcNuts » Thu Sep 25, 2025 11:32 pm
sspell wrote: Thu Sep 25, 2025 8:16 pm
Revision: 1.07
Serial number:
Nope. Firmware is too new. It must be pre 12/2022 to be UHD compatible. You will have to wait for future support.
For UHD enabled drives (AU/NZ/SG + Others) & DIY Single Drive Flasher (WW):
https://uhdenableddrives.com
sspell
Post
by sspell » Thu Sep 25, 2025 11:56 pm
This drive was manufactured august 2021 so the firmware must have been updated. I don't suppose there is a way to flash it back to original?
Post
by MartyMcNuts » Fri Sep 26, 2025 12:22 am
sspell wrote: Thu Sep 25, 2025 11:56 pm
No.
sspell
Post
by sspell » Fri Sep 26, 2025 1:02 am
MartyMcNuts wrote: Fri Sep 26, 2025 12:22 am
No.
Ok will wait for the update's thanks for the reply.
wahyaza
Post
by wahyaza » Wed Oct 08, 2025 8:38 am
My X12 just arrived...anyone able to help out with flashing?
OS device name: J:
Revision: 1.00
Serial number: -
Firmware date: 2019-12-06
Highest AACS version: 82
Firmware version: ID15
Post
by Billycar11 » Wed Oct 08, 2025 9:11 am
wahyaza wrote: Wed Oct 08, 2025 8:38 am
OS device name: J:
Revision: 1.00
Serial number: -
sure email me that info
TheBeardRustler
Post
by TheBeardRustler » Tue Mar 10, 2026 12:35 am
Apologies if there are newer topics.
Anyone able to help if this one can be flashed also?
OS device name: E:
Revision: 1.03
Serial number:
Firmware date: 2020-08-05
Highest AACS version: 81
Drive platform: RS9000
Firmware name: PIONEER BDR-X12T
Firmware version: 1.03/ID56
Post
by Billycar11 » Tue Mar 10, 2026 3:17 am
TheBeardRustler wrote: Tue Mar 10, 2026 12:35 am
OS device name: E:
Revision: 1.03
Serial number:
Sure email me that drive info section see below for email
For all others there is no need to post your makemkv drive info section publicly just email it to me directly
