Pioneer BDR-X12 Flashed with Success!!
Yethidran
Re: Pioneer BDR-X12 Flashed with Success!!
Post by Yethidran »
Billycar11 wrote: Thu Jun 05, 2025 2:44 am
Yethidran wrote: Thu Jun 05, 2025 12:42 am i have too many drives... so getting confused with it all...
Hehehehe!!!!
Enable ask for single drive mode in makemkv looks like it's not from your pics
i tend to rip 4 to 6 different movies at the same time, so i guess single drive mode would not be an option for me..
Hehehehe!!!
Yethidran
Post by Yethidran »
i am using Windows 11 Pro with an, i9, 9900K gen processor..
still going strong and sturdy.
Yethidran wrote: Thu Jun 05, 2025 6:15 pm
Hehehehe!!!!
Hehehehe!!!
Hhhhh it would help with that trust me
You would never get the drive interference I rip 12 at a time for testing drives I would know....
As 1 makemkv instance would only see 1 drive not hold everything up as it looks at each drive
Yethidran
Post by Yethidran »
okie, thanks buddy. cheers!
sspell
Post by sspell »
Need help with flashing this drive to work with MKV UHD any help appreciated. I'm a noob at this ha!
Manufacturer: PIONEER
Product: BD-RW BDR-X12
Revision: 1.07
Serial number:
Firmware date: 2023-08-01
Highest AACS version: 77
Drive platform: Pioneer RS9000
Firmware version: ID56
sspell wrote: Thu Sep 25, 2025 8:16 pm Need help with flashing this drive to work with MKV UHD any help appreciated. I'm a noob at this ha!
Revision: 1.07
Serial number:
Nope. Firmware is too new. It must be pre 12/2022 to be UHD compatible. You will have to wait for future support.
sspell
Post by sspell »
This drive was manufactured august 2021 so the firmware must have been updated. I don't suppose there is a way to flash it back to original?
sspell wrote: Thu Sep 25, 2025 11:56 pm This drive was manufactured august 2021 so the firmware must have been updated. I don't suppose there is a way to flash it back to original?
No.
sspell
Post by sspell »
MartyMcNuts wrote: Fri Sep 26, 2025 12:22 am
No.
Ok will wait for the update's thanks for the reply.
wahyaza
Post by wahyaza »
My X12 just arrived...anyone able to help out with flashing?
OS device name: J:
Revision: 1.00
Serial number: -
Firmware date: 2019-12-06
Highest AACS version: 82
Firmware version: ID15
wahyaza wrote: Wed Oct 08, 2025 8:38 am My X12 just arrived...anyone able to help out with flashing?
OS device name: J:
Revision: 1.00
Serial number: -
sure email me that info
TheBeardRustler
Post by TheBeardRustler »
Apologies if there are newer topics.
Anyone able to help if this one can be flashed also?
OS device name: E:
Revision: 1.03
Serial number:
Firmware date: 2020-08-05
Highest AACS version: 81
Drive platform: RS9000
Firmware name: PIONEER BDR-X12T
Firmware version: 1.03/ID56
TheBeardRustler wrote: Tue Mar 10, 2026 12:35 am Apologies if there are newer topics.
OS device name: E:
Revision: 1.03
Serial number:
Sure email me that drive info section see below for email
For all others there is no need to post your makemkv drive info section publicly just email it to me directly
