Hello
I recently bought a bargain Verbatim 43888, with LG BU40N drive, unfortunately it is bricked, how can I fix it ?
Bricked LG BU40N
Nex122
Bricked LG BU40N
Re: Bricked LG BU40N
What did you do to it??Nex122 wrote: Tue Jun 03, 2025 3:00 pm Hello
You could try using the old ASUS flasher and flash BU40N 1.03-MK firmware. It doesn't do any checks whatsoever so should be able to flash the firmware. viewtopic.php?p=70766#p70766
im also curious what you did
but encrypted fw makes recovery much more complicated it seems
modified lg flasher can also unbrick https://drive.google.com/file/d/102V7DU ... drive_link
Nex122
I bought the used bricked drive. I tried to upload through Flasher asus, and LG, unfortunately I got errors popping up.
What else can I do with it ? Thanks for your help.
Give it back to whomever you bought it from.Nex122 wrote: Wed Jun 04, 2025 6:13 am I bought the used bricked drive. I tried to upload through Flasher asus, and LG, unfortunately I got errors popping up.
Nex122
I was able to fix with this firmware, and now it works as expected (I bought this drive for 10 bucks)
https://www.lg.com/us/support/product/lg-BU40N.AVAA10B
How did you fix it official LG flasher?Nex122 wrote: Thu Jun 05, 2025 6:26 am I was able to fix with this firmware, and now it works as expected (I bought this drive for 10 bucks)
Nex122
I installed first version 1.04 and then 1.05.
but using what flashers?
Nex122
