LibreDrive for Pioneer drives
#1486 Post by Coopervid » Tue Jun 03, 2025 1:52 am
Packers948 wrote: Tue Jun 03, 2025 1:28 am Hello,
Please let me know if this Pioneer – BDR-211UBK would be able to flash for UHD enable. Thank you so much for your help.
MakeMkv information as below.
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-211M
Revision: 1.02
Serial number: NA
Firmware date: 2017-02-23
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8800
Firmware name: PIONEER BDR-211
Firmware version: 1.02/ID60
Did you try an UHD? It should work with your drive as is. If not post again.
Packers948
#1487 Post by Packers948 » Thu Jun 05, 2025 1:02 am
Hi - Thank you for the information - I am going to rip some 4k and Blu Ray disc today - Thanks again
Packers948
#1488 Post by Packers948 » Thu Jun 05, 2025 1:03 am
Coopervid wrote: Tue Jun 03, 2025 1:52 am
OS device name: G:
Revision: 1.02
Serial number: NA
warpgremlin
#1489 Post by warpgremlin » Sat Jun 07, 2025 7:27 pm
Have Pioneer drive (SATA native, via USB enclosure to a Windows box).
UHD disks won't decrypt. Need firmware update... I think.
Product: BD-RW BDR-S13JX
Revision: 1.04
Serial number: xxxxxxxxxxxx
Firmware date: 2022-12-12
Highest AACS version: 61
Firmware version: ID72
#1490 Post by Coopervid » Sat Jun 07, 2025 8:59 pm
warpgremlin wrote: Sat Jun 07, 2025 7:27 pm Have Pioneer drive (SATA native, via USB enclosure to a Windows box).
Revision: 1.04
Not possible currently as your firmware is too new. You have to wait for a solution mike is working on.
Arska
#1491 Post by Arska » Tue Jun 10, 2025 6:25 pm
Hello.
I am sorry to be asking as I am sure that somewhere here there is a reply already.
I've read some conflicting information about whether my drive can or cannot be made to support UHD as its drive platform is "Pioneer RS8510" and some places say that it must be MT1959 or else don't bother. I read that if the drive name has a "U" it supports UHD and mine has. Anyway here is my drive info from MakeMKV:
OS device name: F:
Product: BD-RW BDRUD03AS
Revision: 1.00
Firmware date: 2014-04-01
Highest AACS version: 68
Drive platform: Pioneer RS8510
Firmware version: ID23
Thanks in advance.
#1492 Post by Coopervid » Tue Jun 10, 2025 8:08 pm
Arska wrote: Tue Jun 10, 2025 6:25 pm Hello.
OS device name: F:
Revision: 1.00
Thanks in advance.
PM sent.
Packers948
#1493 Post by Packers948 » Tue Jun 10, 2025 10:14 pm
Hello - Please let me know if this Pioneer BDR-XD08UMB-S would be able to get UHD enable - Thanks
OS device name: G
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: NA
Firmware date: 2022-12-27
Highest AACS version: 77
Drive platform: Pioneer RS9331
Firmware version: ID05
#1494 Post by MartyMcNuts » Wed Jun 11, 2025 12:38 am
Packers948 wrote: Tue Jun 10, 2025 10:14 pm Hello - Please let me know if this Pioneer BDR-XD08UMB-S would be able to get UHD enable - Thanks
OS device name: G
Revision: 1.02
Serial number: NA
No, the firmware is too new (post November 2022). You will have to wait for support, which should happen at some point in the future.
Ryoga
#1495 Post by Ryoga » Fri Jun 20, 2025 7:54 am
Hello - I would like to enable Libredrive for this drive. Can someone help me to flash it ?
Informations below - thanks in advance
OS device name: G:
Manufacturer: ASUS
Product: SBC-06D2X-U
Revision: 1.02
Serial number:
Firmware date: 2016-11-02
Drive platform: Pioneer RS8590
Firmware version: ID22
#1496 Post by Coopervid » Fri Jun 20, 2025 11:11 am
Ryoga wrote: Fri Jun 20, 2025 7:54 am Hello - I would like to enable Libredrive for this drive. Can someone help me to flash it ?
OS device name: G:
Manufacturer: ASUS
Revision: 1.02
Serial number: PKDL009527WL
No. Yours is a BD combo. Only BD writers can be flashed.
cinegrow
#1497 Post by cinegrow » Sat Jun 21, 2025 11:16 pm
supported - original vendor firmware (Pioneer RS): 210 firmware(s):
PIONEER-BD-RW_BDR-XS05WF-1.41-B6BE50FD-8221ID25-20140402
PIONEER-BD-RW___BDR-TD05-1.00-DCD80C11-8211ID01-20120713
PIONEER-BD-RW___BDR-TD05-1.02-F9240B3B-8211-20140619
spl147 wrote: Thu Nov 09, 2023 11:22 pm does anyone have v.1.02 firmware for this drive?
label says BDR-TD05FAD
Hello. Can somone confirm or not is LibreDrive work on BDR-TD05FAD? Or maybe BDR-TD05D/BDR-TD05AS?
Or it's a same model? Thank you.
#1498 Post by Coopervid » Sun Jun 22, 2025 8:27 am
cinegrow wrote: Sat Jun 21, 2025 11:16 pm
You need to post your Makemkv info. However, this drive will not read UHDs even if the firmware would be updated.
jiujitsuguy
#1499 Post by jiujitsuguy » Sun Jun 22, 2025 7:41 pm
Hi all! New to the 4k scene and was looking for help on getting my drive to work with UHD discs. Thanks in advance!
OS device name: E:
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Highest AACS version: 65
#1500 Post by Billycar11 » Sun Jun 22, 2025 10:53 pm
jiujitsuguy wrote: Sun Jun 22, 2025 7:41 pm Hi all! New to the 4k scene and was looking for help on getting my drive to work with UHD discs. Thanks in advance!
OS device name: E:
Revision: 1.14
Serial number:
Yeah just send that info to my email see below
