Bricked LG BU40N
Nex122
Bricked LG BU40N
Post by Nex122 » Tue Jun 03, 2025 3:00 pm
Hello
I recently bought a bargain Verbatim 43888, with LG BU40N drive, unfortunately it is bricked, how can I fix it ?
Zrzut ekranu 2025-06-03 165406.png (31.04 KiB) Viewed 5466 times
Zrzut ekranu 2025-06-03 165943.png (19.53 KiB) Viewed 5466 times
Re: Bricked LG BU40N
Post by MartyMcNuts » Wed Jun 04, 2025 12:36 am
Nex122 wrote: Tue Jun 03, 2025 3:00 pm Hello
What did you do to it??
You could try using the old ASUS flasher and flash BU40N 1.03-MK firmware. It doesn't do any checks whatsoever so should be able to flash the firmware. viewtopic.php?p=70766#p70766
Post by Billycar11 » Wed Jun 04, 2025 2:43 am
im also curious what you did
but encrypted fw makes recovery much more complicated it seems
modified lg flasher can also unbrick https://drive.google.com/file/d/102V7DU ... drive_link
Nex122
Post by Nex122 » Wed Jun 04, 2025 6:13 am
I bought the used bricked drive. I tried to upload through Flasher asus, and LG, unfortunately I got errors popping up.
What else can I do with it ? Thanks for your help.
Post by MartyMcNuts » Thu Jun 05, 2025 3:14 am
Nex122 wrote: Wed Jun 04, 2025 6:13 am I bought the used bricked drive. I tried to upload through Flasher asus, and LG, unfortunately I got errors popping up.
Give it back to whomever you bought it from.
Nex122
Post by Nex122 » Thu Jun 05, 2025 6:26 am
I was able to fix with this firmware, and now it works as expected (I bought this drive for 10 bucks) :)
https://www.lg.com/us/support/product/lg-BU40N.AVAA10B
Post by Billycar11 » Thu Jun 05, 2025 1:46 pm
Nex122 wrote: Thu Jun 05, 2025 6:26 am I was able to fix with this firmware, and now it works as expected (I bought this drive for 10 bucks) :)
How did you fix it official LG flasher?
Nex122
Post by Nex122 » Mon Jun 09, 2025 11:48 am
I installed first version 1.04 and then 1.05.
Post by Billycar11 » Mon Jun 09, 2025 12:24 pm
Nex122 wrote: Mon Jun 09, 2025 11:48 am I installed first version 1.04 and then 1.05.
but using what flashers?
Nex122
Post by Nex122 » Tue Jun 10, 2025 7:54 am
