edmsms wrote: Sun May 04, 2025 1:55 am Same model: ASUS SBW-06D5H-U. It can be flashed?
PM sent.
edmsms
Post by edmsms »
Coopervid wrote: Sun May 04, 2025 9:39 am
PM sent.
Thanks man, this worked 100%. Is it possible to do something similar with this drive?
Captura de tela 2025-05-22 005947.png (11.22 KiB) Viewed 49434 times
edmsms wrote: Thu May 22, 2025 4:00 am
PM sent.
No.
edmsms
Post by edmsms »
Coopervid wrote: Wed Jun 04, 2025 4:48 am
PM sent.
No.
Hey, just passing by to thank you and everyone on this site, especially: Pat LaVarre, >NIL:, Agent Smith, Liggy, Mike Chen, ala42, czary2mary, jadburner, cvs, alexx12345, seku, Leman39, wujooj, jurireal, alphaville0527, SnowFox, Kirby, haysey70, Majestic12, elflorek, floppydumper, redwine, cryptojoe3737, TeddyRaspin, Billycar11, asmcom, Coopervid (thanks again), payalnik23, and aliter404.
Later, after reading the pinned post, I discovered that this drive was too old to be flashed, but with my third drive (WH14NS40), I managed to flash it to ---> WH16NS60. Thanks again, everyone. You’re awesome!
Just one question: I noticed that there are 3 different programs to flash the drives (BDRFlash, makemkvcon, and SDFGUI). All three worked correctly, but I just want to know if there are any differences between them. Thanks again, folks! :D
edmsms wrote: Tue Jun 10, 2025 9:49 am
No.
There is BDRFlash for Pioneer drives. Makekmvcon and the GUI for it written by Marty is SDFTool which uses Makemkvcon for LG / ASUS drives.
draughthorse
Post by draughthorse »
hi, i was wondering if my ASUS SBW-06D5H-U is flashable?
draughthorse wrote: Fri Jun 13, 2025 7:50 pm hi, i was wondering if my ASUS SBW-06D5H-U is flashable?
Yes. Use SDFTool and flash to BU40N.
draughthorse
Coopervid wrote: Sun Jun 22, 2025 2:11 pm
are you sure... im reading the uhd drive flashing guide and it tells me specifically not to crossflash between asus and lg because it will brick my drive. is there something im missing?
draughthorse wrote: Sun Jun 22, 2025 9:55 pm
Yes. It's a slim drive. The warning is meant not to flash firmware of full size drives to slim drives and vice versa
sid87
Post by sid87 »
Hi! I've also the same model, I'd like to know if mine can be flashed:
Captura de pantalla 2025-06-26 232538.png (34.55 KiB) Viewed 47653 times
sid87 wrote: Thu Jun 26, 2025 9:27 pm Hi! I've also the same model, I'd like to know if mine can be flashed:
sure email me that drive info below
draughthorse
Coopervid wrote: Mon Jun 23, 2025 7:12 pm
thanks, ive tested it and it works :D
davinci247
Post by davinci247 »
Hi all,
I have this drive model also. Does it Support 4K Blurays out of the box, or do I need to flash it? If so, where do I find the correct firmware?
OS device name: /dev/rdisk4
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E101
Serial number: SCDL117238WL
Firmware date: 2018-08-22
Highest AACS version: 76
Drive platform: RS8511
Firmware version: E101/ID26
davinci247 wrote: Tue Jul 08, 2025 8:59 pm Hi all,
Manufacturer: ASUS
Revision: E101
PM sent for flashing it
davinci247
thanks! Just got around to flashing now, worked just fine :)
cheers!
