ASUS SBW-06D2X-U
Re: ASUS SBW-06D2X-U
#196 Post by Coopervid » Mon Jun 02, 2025 6:15 am
ashahzadpk wrote: Mon Jun 02, 2025 4:50 am
ashahzadpk wrote: Sat May 31, 2025 5:30 am Drive Information
OS device name: I:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: ...
Firmware date: 2017-04-18
Firmware version: ID22
please help. thanks in advance
Still waiting for response Please help
Still waiting Please Help
PM sent.
ashahzadpk
#197 Post by ashahzadpk » Mon Jun 02, 2025 7:49 pm
Coopervid wrote: Mon Jun 02, 2025 6:15 am
OS device name: I:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
Thank you worked perfectly
PM sent.
zShionz
#198 Post by zShionz » Mon Jun 02, 2025 8:35 pm
Coopervid wrote: Mon Jun 02, 2025 6:14 am
zShionz wrote: Sun Jun 01, 2025 4:11 pm Hi, I have this Blu-ray and I would like to make it compatible with UHD discs.
OS device name: H:
Manufacturer: ASUS
Revision: 1.10
Serial number:
thank you.
PM sent.
Thank you very much, it worked now I can read UHD Blu-rays.
Turkechy
#199 Post by Turkechy » Tue Jun 03, 2025 5:04 am
Please, I have the same problem.
Can you help me find the solution?
Regards
Información de unidad de disco
Nombre del SO del dispositivo: G:
Fabricante: ASUS
Producto: SBW-06D2X-U
Revisión: 1.10
Número de serie: ...
Fecha del firmware: 2017-04-18
Marcas de cifrado bus: 1B
No hay disco insertado
Darkseason
#200 Post by Darkseason » Tue Jun 03, 2025 11:59 am
So I have the same drive model etc as the op but lost as what to do, I have tried loading uhd disks with no luck so assuming I need to update my firmware but lost as to which to load.
OS device name: K:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
Yukikaze
#201 Post by Yukikaze » Tue Jun 03, 2025 11:58 pm
I just got one of these drives. It's manufactured in 2012. Seems to be Sony drive in it.
OS device name: E:
Manufacturer: ASUS
Revision: C701
Serial number: ...
Highest AACS version: 28
Is libredrive supported on this?
#202 Post by Woodstock » Wed Jun 04, 2025 12:18 am
clarification - "LibreDrive" does NOT mean "can read UHD disks". A drive built before UHD was available (like this one) is not likely to support it just by having its firmware unlocked.
#203 Post by Coopervid » Wed Jun 04, 2025 3:40 am
Turkechy wrote: Tue Jun 03, 2025 5:04 am Please, I have the same problem.
Regards
Fabricante: ASUS
Revisión: 1.10
PM sent.
#204 Post by Coopervid » Wed Jun 04, 2025 3:42 am
Darkseason wrote: Tue Jun 03, 2025 11:59 am So I have the same drive model etc as the op but lost as what to do, I have tried loading uhd disks with no luck so assuming I need to update my firmware but lost as to which to load.
OS device name: K:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
PM sent.
#205 Post by Coopervid » Wed Jun 04, 2025 3:45 am
Yukikaze wrote: Tue Jun 03, 2025 11:58 pm I just got one of these drives. It's manufactured in 2012. Seems to be Sony drive in it.
OS device name: E:
Manufacturer: ASUS
Revision: C701
Serial number: ...
You need to post the full information including "Drive platform".
zittrig
#206 Post by zittrig » Thu Jun 05, 2025 5:22 am
I've a problem with an ASUS SBW-06D2X-U from a friend. First, he's a smoker so the drive smells and looks terrible.
The drive is flashed to BDR-UD04 1.14 so far so good. Recognition of CD/DVD with the red laser is great but recognition of BD / 4K ..... also terrible. Some yes, some no, some after multible opening and closing and trying again.
I've cleaned the laser twice. Recognition better. Testing multiple times with discs that were previously not detected or difficult was successful. But not all .... For safety times another cable tested, no further success, then the lenses cleaned three more times, the detection rate has continued to rise.
Basically, I am now at the point that, all discs are detected, up to 3-layer discs. Tested multiple times with different discs, which do not cause problems in another same drive. Here you have to open and close the load several times and eventually the discs will be recognized. Can it be done by the laser? I always went out of principle, laser does not work or works, but here I have the feeling that the laser does what he wants ..... Or is the laser not the cause?
#207 Post by Coopervid » Thu Jun 05, 2025 5:31 am
zittrig wrote: Thu Jun 05, 2025 5:22 am I've a problem with an ASUS SBW-06D2X-U from a friend. First, he's a smoker so the drive smells and looks terrible.
Firstly -this is the laser lens that was / is polluted. Yes, lasers can deteriote as well and weaken but then writing causes a problem because laser power for writing is almost 10x compared to reading. Power supply can be an issue as well if the drive is in an enclosure. USB3 power or a powered hub usually helps.
Try again cleaning the lens with alcohol, not just water etc. But yes, the drive (laser) might be dying and then you can't do anything. Try do burn a disc. If that fails then the laser is bad.
zittrig
#208 Post by zittrig » Thu Jun 05, 2025 5:56 am
Thanks for your reply :!:
Lenses are cleaned with alcohol, of course. What is good for me will be also good for the lenses ....
Power comes with an USB-Y-Power cable. That shouldn't be the problem, I think. But I'll ask another friend for his powered hub.
The hint with testing the drive by burning a BD will be tested after work. I will report then.
#209 Post by Coopervid » Thu Jun 05, 2025 6:06 am
zittrig wrote: Thu Jun 05, 2025 5:56 am Thanks for your reply :!:
You are very welcome! The lens will most likely appreciate a higher content percentage on alcohol as you do :D :D .
Darkseason
#210 Post by Darkseason » Thu Jun 05, 2025 10:04 am
Coopervid wrote: Wed Jun 04, 2025 3:42 am
OS device name: K:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
PM sent.
Thank you, thank you, thank you. This recycles my drive with new life for sure. Wish I had found ya'll much sooner.
