DC-2187
#2971 Post by DC-2187 » Sat May 31, 2025 12:31 am
MartyMcNuts wrote: Sat May 31, 2025 12:23 am
DC-2187 wrote: Fri May 30, 2025 9:03 pm Just to clarify if I'm buying a Pioneer drive that is a 4k model and would not need to be flashed and was made in 2023..that would still work with makemkv?
Not for UHD currently. Only Pioneer drives with firmware prior to December 2022 are/can be made UHD compatible.
Sometime in the future, those with firmware from December 2022 onwards will be able to be flashed for UHD compatibility.
Oh I see thanks for the response. I guess I will hold off. I figured maybe a 4k model drive would work but oh well. Good thing I asked before buying
#2972 Post by MartyMcNuts » Sat May 31, 2025 12:35 am
DC-2187 wrote: Sat May 31, 2025 12:31 am
The issue is, to be able to rip UHD discs, LibreDrive mus be enabled for the drive and any Pioneer (UHD/Non UHD) with firmware from Dec 2022 onwards cannot currently have LibreDrive enabled. This is expected to happen sometime in the future.
qnixgamer
#2973 Post by qnixgamer » Sat May 31, 2025 5:59 pm
OS device name: E:
Current profile: CD-ROM
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E102
Serial number: ,,,
Firmware date: 2023-04-20
Firmware version: ID26
Is there way to make drive UHD compatible?
Packers948
#2974 Post by Packers948 » Sun Jun 01, 2025 2:15 am
Hi - Please let me know what LG firmware would be best for this drive WH16NS46. Thank you
MakeMkv information as below.
OS device name: G:
Product: BD-RE WH16NS46
Revision: 1.05
Serial number: NA
Firmware date: 2122-01-14 11:38
Highest AACS version: 77
#2975 Post by MartyMcNuts » Sun Jun 01, 2025 3:08 am
qnixgamer wrote: Sat May 31, 2025 5:59 pm Drive Information
OS device name: E:
Manufacturer: ASUS
Revision: E102
Serial number: ,,,
Not at this time. Firmware is too new. You need to wait until some time in the future when Pioneer drives with firmware from December 2022 onwards are supported.
Jimothy
#2976 Post by Jimothy » Tue Jun 03, 2025 8:56 pm
Hi there,
Ive been reading through the board here and would like to ask somebody if they know whether or not my drive can be successfully flashed?
OS device name: /dev/rdisk5
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BU14
Serial number: 00000000000
Firmware date: 2121-06-21 13:30
Bus encryption flags: 1F
Highest AACS version: 72
that's the info from MakeMKV info panel, it seems as if I have firmware from a hundred years in the future?!?!? some help would be most appreciated, thanks
#2977 Post by MartyMcNuts » Wed Jun 04, 2025 12:28 am
Jimothy wrote: Tue Jun 03, 2025 8:56 pm Hi there,
Revision: BU14
Yes, MakeMKV shows the firmware date as 2121 instead of 2021.
Yeah, you can flash it to BU40N 1.03-MK.
tyme2tb
#2978 Post by tyme2tb » Wed Jun 04, 2025 1:00 am
Would the below be able to be flashed to do UHD
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.10
Serial number: xxxxxxxxxxx
Firmware date: 2013-09-10
Bus encryption flags: 13
Drive platform: RS8600
Firmware version: 1.10/ID60
nathanm5764
#2979 Post by nathanm5764 » Fri Jun 06, 2025 9:49 am
Hi, I appear to have a newish (2020) drive with oldish (2017) firmware, could you advise on what (if any) firmware I can flash with to get LibreDrive functionality?
OS device name: E:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: T*********L
Firmware date: 2017-04-18
Highest AACS version: 12
Firmware version: ID22
Sam88
#2980 Post by Sam88 » Tue Jun 10, 2025 7:00 pm
I just purchased a Verbatim 43888, because it was frequently suggested.
Can you tell me if it is flashable and which Firmware to use?
OS device name: E:
Product: BDDVDRW GGC-H20L
Revision: 1.02
Serial number: ...
Firmware date: 2007-12-27 12:34:56
Status: Possible, might be supported in future, but not likely soon
Drive platform: RS1013
Firmware version: 1.02-
#2981 Post by Coopervid » Tue Jun 10, 2025 9:39 pm
Sam88 wrote: Tue Jun 10, 2025 7:00 pm Hello,
OS device name: E:
Revision: 1.02
Serial number: ...
Not possible.
#2982 Post by Coopervid » Tue Jun 10, 2025 9:40 pm
tyme2tb wrote: Wed Jun 04, 2025 1:00 am Would the below be able to be flashed to do UHD
OS device name: G:
Revision: 1.10
PM sent.
#2983 Post by Coopervid » Tue Jun 10, 2025 9:42 pm
nathanm5764 wrote: Fri Jun 06, 2025 9:49 am Hi, I appear to have a newish (2020) drive with oldish (2017) firmware, could you advise on what (if any) firmware I can flash with to get LibreDrive functionality?
OS device name: E:
Manufacturer: ASUS
Revision: 1.10
PM sent.
tyme2tb
#2984 Post by tyme2tb » Wed Jun 11, 2025 2:13 am
Coopervid wrote: Tue Jun 10, 2025 9:40 pm PM sent.
Thanks.
PM was for 211 drives, so I just wanted to double check that is works for the 209 also which is what mine is.
#2985 Post by Coopervid » Wed Jun 11, 2025 7:05 am
It will make your 209 a S11 / 211.
