Post by SamuriHL » Sat May 31, 2025 1:55 pm
For me personally I'm thinking jriver mc support. It would definitely be ideal, especially with fel.
pitrako
Post by pitrako » Sat May 31, 2025 3:13 pm
Why the dolby vision mode toggle doesn't work outside lg tv? It's possible to enable this on other brand tv like philips?, I have the toggle on windows but It does nothing.
Post by RESET_9999 » Sat May 31, 2025 3:29 pm
pitrako wrote: Sat May 31, 2025 3:13 pm Why the dolby vision mode toggle doesn't work outside lg tv? It's possible to enable this on other brand tv like philips?, I have the toggle on windows but It does nothing.
My G5 has a DV PC mode and is seen as DV capable on Windows. Without it, DV is not triggered, so you'll probably have to modify your EDID, see: https://github.com/balu100/dolby-vision-for-windows
pitrako
Post by pitrako » Sat May 31, 2025 3:49 pm
My tv has dolby vision certification:
Post by RESET_9999 » Sat May 31, 2025 3:55 pm
strange that it doesnt work then...
kazuma
Post by kazuma » Mon Jun 02, 2025 9:01 pm
Jellyfin plays dolby vision mkv from my lg g4 internal app. Does anybody knows if it does properly? (all profiles?)
Post by RESET_9999 » Mon Jun 02, 2025 10:24 pm
kazuma wrote: Mon Jun 02, 2025 9:01 pm Jellyfin plays dolby vision mkv from my lg g4 internal app. Does anybody knows if it does properly? (all profiles?)
It won’t be better or worse than any other internal player/container, and once you get the webOS 2025 update, PLEX and the G4 native player should support DV MKV too.
In fact, all the TVs that are eligible for webOS 2025 should get DV MKV support.
PS: just ordered the kaleidescape. We will know soon enough how it compares to the UHD-BD quality :twisted:
daffie
Post by daffie » Tue Jun 03, 2025 8:08 am
@RESET_9999
How is the HDR10 of the movie Flow (2024) ? Is it just SDR in a HDR container ?
Would love a decent DoVi RPU of that movie. Is that Generated T3 xml a good one?
LG OLED65G1RLA / Samsung HW-Q990D / Panasonic UB820 / Ugoos AM6B+ (CE with avdvplus Build)
Post by RESET_9999 » Tue Jun 03, 2025 10:33 am
of course, it's a good one?
movie is 200nits
daffie
Post by daffie » Tue Jun 03, 2025 11:21 am
200 nits. That is basically SDR in a HDR container :wink:
Post by RESET_9999 » Tue Jun 03, 2025 11:29 am
yes but the average is very high so it wont feel dark at all. will post a comparison on youtube later, just waiting on the YT HDR encoding to publish it...
foxbat
Post by foxbat » Tue Jun 03, 2025 11:56 am
RESET_9999 wrote: Mon Jun 02, 2025 10:24 pm PS: just ordered the kaleidescape. We will know soon enough how it compares to the UHD-BD quality :twisted:
That's cool - you got the Strato E I presume?
Do those boxes support playback of non- K sourced media? Like via USB for example? For testing what formats it actually supports?
I'm also interested what DV profile the K files use. 7? 8? Maybe even 5?
kazuma
Post by kazuma » Tue Jun 03, 2025 12:09 pm
What is an kaleidescape? :D
Post by RESET_9999 » Tue Jun 03, 2025 12:10 pm
foxbat wrote: Tue Jun 03, 2025 11:56 am
I'm also interested what DV profile the K files use? 7? 8? Maybe even 5?
Yep, the cheapest model. No USB playback, this device is only good for accessing the Kscape store.
They offer DV P5, HDR10 and SDR with bitrate almost always higher than the bluray disc. (encoded straight from studio's master). P5(11.5bits) is no different than P7(12bit) on our 10bits TV.
you can read here: https://www.kscapeowners.com/XF/threads ... -fel.6609/
Post by RESET_9999 » Tue Jun 03, 2025 12:13 pm
kazuma wrote: Tue Jun 03, 2025 12:09 pm What is an kaleidescape? :D
it's a very expensive streaming service/box with lossless audio and 100mbps bitrate encodes. It also have many HDR/4K release not available on disc.
https://www.kaleidescape.com/movie-store/movies
In each movie description, you can see the file size of the stream.
