Post by RESET_9999 » Sat May 31, 2025 12:46 pm
DV windows update is available outside the DEV mode, and surprisingly, it does true TV-LED.
Win10 still has the red push bug though.
For older TV, you might have to modify your EDID but I heard you can use the LG dolby access app to enable it.
https://github.com/balu100/dolby-vision-for-windows
https://www.reddit.com/r/LGOLED/comment ... leds_with/
Post by SamuriHL » Sat May 31, 2025 1:39 pm
Fascinating. I wonder if we'll see player updates on Windows to enable Dolby vision playback. That'd be sweet.
Post by RESET_9999 » Sat May 31, 2025 1:43 pm
Well, Energy Player can already do DV MKV + lossless audio as well as P7 to P8 playback, but that would be nice with MPC-HC/BE + some sort of dovi_baker plugin for FEL... It might be possible one day...
Post by SamuriHL » Sat May 31, 2025 1:55 pm
For me personally I'm thinking jriver mc support. It would definitely be ideal, especially with fel.
pitrako
Post by pitrako » Sat May 31, 2025 3:13 pm
Why the dolby vision mode toggle doesn't work outside lg tv? It's possible to enable this on other brand tv like philips?, I have the toggle on windows but It does nothing.
Post by RESET_9999 » Sat May 31, 2025 3:29 pm
My G5 has a DV PC mode and is seen as DV capable on Windows. Without it, DV is not triggered, so you'll probably have to modify your EDID, see: https://github.com/balu100/dolby-vision-for-windows
pitrako
Post by pitrako » Sat May 31, 2025 3:49 pm
My tv has dolby vision certification:
Post by RESET_9999 » Sat May 31, 2025 3:55 pm
strange that it doesnt work then...
kazuma
Post by kazuma » Mon Jun 02, 2025 9:01 pm
Jellyfin plays dolby vision mkv from my lg g4 internal app. Does anybody knows if it does properly? (all profiles?)
Post by RESET_9999 » Mon Jun 02, 2025 10:24 pm
It won’t be better or worse than any other internal player/container, and once you get the webOS 2025 update, PLEX and the G4 native player should support DV MKV too.
In fact, all the TVs that are eligible for webOS 2025 should get DV MKV support.
PS: just ordered the kaleidescape. We will know soon enough how it compares to the UHD-BD quality :twisted:
daffie
Post by daffie » Tue Jun 03, 2025 8:08 am
@RESET_9999
How is the HDR10 of the movie Flow (2024) ? Is it just SDR in a HDR container ?
Would love a decent DoVi RPU of that movie. Is that Generated T3 xml a good one?
LG OLED65G1RLA / Samsung HW-Q990D / Panasonic UB820 / Ugoos AM6B+ (CE with avdvplus Build)
Post by RESET_9999 » Tue Jun 03, 2025 10:33 am
of course, it's a good one?
movie is 200nits
daffie
Post by daffie » Tue Jun 03, 2025 11:21 am
200 nits. That is basically SDR in a HDR container :wink:
Post by RESET_9999 » Tue Jun 03, 2025 11:29 am
yes but the average is very high so it wont feel dark at all. will post a comparison on youtube later, just waiting on the YT HDR encoding to publish it...
foxbat
Post by foxbat » Tue Jun 03, 2025 11:56 am
That's cool - you got the Strato E I presume?
Do those boxes support playback of non- K sourced media? Like via USB for example? For testing what formats it actually supports?
I'm also interested what DV profile the K files use. 7? 8? Maybe even 5?
