#11011 Post by RESET_9999 » Sat May 31, 2025 12:46 pm
DV windows update is available outside the DEV mode, and surprisingly, it does true TV-LED.
Win10 still has the red push bug though.
For older TV, you might have to modify your EDID but I heard you can use the LG dolby access app to enable it.
https://github.com/balu100/dolby-vision-for-windows
https://www.reddit.com/r/LGOLED/comment ... leds_with/
#11012 Post by SamuriHL » Sat May 31, 2025 1:39 pm
Fascinating. I wonder if we'll see player updates on Windows to enable Dolby vision playback. That'd be sweet.
#11013 Post by RESET_9999 » Sat May 31, 2025 1:43 pm
SamuriHL wrote: Sat May 31, 2025 1:39 pm Fascinating. I wonder if we'll see player updates on Windows to enable Dolby vision playback. That'd be sweet.
Well, Energy Player can already do DV MKV + lossless audio as well as P7 to P8 playback, but that would be nice with MPC-HC/BE + some sort of dovi_baker plugin for FEL... It might be possible one day...
#11014 Post by SamuriHL » Sat May 31, 2025 1:55 pm
For me personally I'm thinking jriver mc support. It would definitely be ideal, especially with fel.
pitrako
#11015 Post by pitrako » Sat May 31, 2025 3:13 pm
Why the dolby vision mode toggle doesn't work outside lg tv? It's possible to enable this on other brand tv like philips?, I have the toggle on windows but It does nothing.
#11016 Post by RESET_9999 » Sat May 31, 2025 3:29 pm
pitrako wrote: Sat May 31, 2025 3:13 pm Why the dolby vision mode toggle doesn't work outside lg tv? It's possible to enable this on other brand tv like philips?, I have the toggle on windows but It does nothing.
My G5 has a DV PC mode and is seen as DV capable on Windows. Without it, DV is not triggered, so you'll probably have to modify your EDID, see: https://github.com/balu100/dolby-vision-for-windows
pitrako
#11017 Post by pitrako » Sat May 31, 2025 3:49 pm
My tv has dolby vision certification:
#11018 Post by RESET_9999 » Sat May 31, 2025 3:55 pm
strange that it doesnt work then...
kazuma
#11019 Post by kazuma » Mon Jun 02, 2025 9:01 pm
Jellyfin plays dolby vision mkv from my lg g4 internal app. Does anybody knows if it does properly? (all profiles?)
#11020 Post by RESET_9999 » Mon Jun 02, 2025 10:24 pm
kazuma wrote: Mon Jun 02, 2025 9:01 pm Jellyfin plays dolby vision mkv from my lg g4 internal app. Does anybody knows if it does properly? (all profiles?)
It won’t be better or worse than any other internal player/container, and once you get the webOS 2025 update, PLEX and the G4 native player should support DV MKV too.
In fact, all the TVs that are eligible for webOS 2025 should get DV MKV support.
PS: just ordered the kaleidescape. We will know soon enough how it compares to the UHD-BD quality :twisted:
daffie
#11021 Post by daffie » Tue Jun 03, 2025 8:08 am
@RESET_9999
How is the HDR10 of the movie Flow (2024) ? Is it just SDR in a HDR container ?
Would love a decent DoVi RPU of that movie. Is that Generated T3 xml a good one?
LG OLED65G1RLA / Samsung HW-Q990D / Panasonic UB820 / Ugoos AM6B+ (CE with avdvplus Build)
#11022 Post by RESET_9999 » Tue Jun 03, 2025 10:33 am
of course, it's a good one?
movie is 200nits
daffie
#11023 Post by daffie » Tue Jun 03, 2025 11:21 am
200 nits. That is basically SDR in a HDR container :wink:
#11024 Post by RESET_9999 » Tue Jun 03, 2025 11:29 am
yes but the average is very high so it wont feel dark at all. will post a comparison on youtube later, just waiting on the YT HDR encoding to publish it...
foxbat
#11025 Post by foxbat » Tue Jun 03, 2025 11:56 am
RESET_9999 wrote: Mon Jun 02, 2025 10:24 pm PS: just ordered the kaleidescape. We will know soon enough how it compares to the UHD-BD quality :twisted:
That's cool - you got the Strato E I presume?
Do those boxes support playback of non- K sourced media? Like via USB for example? For testing what formats it actually supports?
I'm also interested what DV profile the K files use. 7? 8? Maybe even 5?
