I just found i have another one need to submit here and i forgot to attach it and now im doing it.
sorry for duplicated post!
AACS v82 Blu-ray Disc dump submission
Re: AACS v82 Blu-ray Disc dump submission
This one should be in the keydb. Download and extract it to your MakeMKV data directory (the directory that you found the dump file) or if you're on windows you can use my tool to do that for you.
viewtopic.php?f=12&t=16883&p=166510#p166510
mccheng0802
for real?SamuriHL wrote: Tue Jun 03, 2025 4:03 pm This one should be in the keydb. Download and extract it to your MakeMKV data directory (the directory that you found the dump file) or if you're on windows you can use my tool to do that for you.
because i try to find "AKARI_KITO" in the file that i downloaded from FindVUK, i can't see any info related to my BD (which the title is "All Light!")
Am i doing something wrong?
No, you should be searching for the Disc ID: 59a6db40815898f504027e710c2d76d6df5ac618 which is the SHA-1 of the Unit_Key_RO.inf file.mccheng0802 wrote: Wed Jun 04, 2025 11:35 amfor real?SamuriHL wrote: Tue Jun 03, 2025 4:03 pm This one should be in the keydb. Download and extract it to your MakeMKV data directory (the directory that you found the dump file) or if you're on windows you can use my tool to do that for you.
mccheng0802
but when i tried to put "keydb.cfg" and changed it to "KEYDB.cfg" into MakeMKV data directory, still not working.MartyMcNuts wrote: Thu Jun 05, 2025 3:06 amNo, you should be searching for the Disc ID: 59a6db40815898f504027e710c2d76d6df5ac618 which is the SHA-1 of the Unit_Key_RO.inf file.mccheng0802 wrote: Wed Jun 04, 2025 11:35 amfor real?SamuriHL wrote: Tue Jun 03, 2025 4:03 pm This one should be in the keydb. Download and extract it to your MakeMKV data directory (the directory that you found the dump file) or if you're on windows you can use my tool to do that for you.
also how can you know the disc ID via the Unit_Key_RO.inf file? i open it with notepad++ and nothing show.
thanks for helping!
As I said before, the discID is the SHA-1 of the Unit_Key_RO.inf file. And, yes, there is a record for your disc that includes the VUK in the latest KeyDB file.mccheng0802 wrote: Thu Jun 05, 2025 6:50 ambut when i tried to put "keydb.cfg" and changed it to "KEYDB.cfg" into MakeMKV data directory, still not working.MartyMcNuts wrote: Thu Jun 05, 2025 3:06 amNo, you should be searching for the Disc ID: 59a6db40815898f504027e710c2d76d6df5ac618 which is the SHA-1 of the Unit_Key_RO.inf file.mccheng0802 wrote: Wed Jun 04, 2025 11:35 am
for real?
thanks for helping!
I don't think the case matters. At least not for Windows anyway. My file is called KeyDB.cfg.
mccheng0802
thankyou! after i change the file name to KeyDB.cfg and it works for me!MartyMcNuts wrote: Thu Jun 05, 2025 7:00 amAs I said before, the discID is the SHA-1 of the Unit_Key_RO.inf file. And, yes, there is a record for your disc that includes the VUK in the latest KeyDB file.mccheng0802 wrote: Thu Jun 05, 2025 6:50 ambut when i tried to put "keydb.cfg" and changed it to "KEYDB.cfg" into MakeMKV data directory, still not working.MartyMcNuts wrote: Thu Jun 05, 2025 3:06 am
thanks for helping!
i don't know why KEYDB.cfg or keydb.cfg not working but whatever
thanks for the help!!
Awesome glad you got it working. Thanks Marty for helping!
