WH14NS40 "Boot" can't be upgraded
plshelp
Post by plshelp » Sat May 20, 2023 8:36 am
Hi Folks,
I just swapped out my dvd writer for this lg bluray writer and I'm trying to update the firmware of my WH14NS40 (2013), because it is not being seen as a bluray drive/writer by Windows as it sees the drive as a dvd/cdrw. Power2go13 fails seeing it as a burner altogether (burner not available or no rights to access). I tried all of the current firmware on the LG site, but after a reboot, I am still seeing the "boot" revision instead of the version that was installed.
The SDF tool will allow me to choose the correct firmware (v1.02), but it can't be read or written due to the MT1959 platform missing.
This drive does not seem to want to cooperate. I am at a loss and need your help.
Product: BD-RE WH14NS40
Revision: BOOT
tikifire
Re: WH14NS40 "Boot" can't be upgraded
Post by tikifire » Thu Mar 07, 2024 4:05 am
I'm having a similar problem with the same year and model drive. I was able to change the firmware using the older sdf tool but now it's showing "boot", the blue light just flashes a couple of times in a row every few seconds and won't open.
I've tried recovery but that doesn't do anything when I hit start. I've also tried doing it manually through commands and just get error codes.
Post by dcoke22 » Thu Mar 07, 2024 2:53 pm
The Ultimate UHD Drives Flashing Guide makes pretty clear that if your drive is from 2015 or older and/or has the MT1939 platform that you should leave it alone. I'm pretty sure the latest versions of the SDFtool try to detect when a user is about to flash a drive that's too old and prevents it, which is probably why you had to use an old version of SDFTool.
The easiest thing to do now is buy a new drive.
tikifire
Post by tikifire » Thu Mar 07, 2024 3:20 pm
I was able to get it working again using the asus flasher. Thanks.
HWJHAL
Post by HWJHAL » Mon Jun 02, 2025 11:33 pm
Wow, the Asus flash utility(modified) fixed my drive as well I just selected the original firmware version 1.01 for my WH14NS40 and it flashed it back to working condition. Nothing else I tried worked only this method.
ENORM
Post by ENORM » Tue Dec 02, 2025 11:02 am
Hi !
I have a BH16NS40 Manufactured: November 2023 and SVC Code: NS51 (Info from the label on the drive)
OS device name: E:
Product: BD-RE BH16NS60
Revision: BOOT
Highest AACS version: 82
Eject button is not working, so... What can I do ? I've tried this method (using ASUS_ODD_FW_Changer_(Modified).exe and DE_LG_WH16NS40_1.02_NS50.bin) but I just get an Updating Failure #5 error.
Can you help me?
