failed to open ripped Blu-ray file at 1.7.0
tomokatsu
#1 Post by tomokatsu » Sun Jan 01, 2012 5:52 am
Hi.
I use MakeMKV BETA 1.7.0.
I tried to open ripped BDMV file by MakeMKV BETA 1.7.0.
Ripped tool is AnyDVD HD, blu-ray title is Batman begins.
then, MakeMKV occurred read error. "Volume key is unknown."
Could you tell me to solve this problem.
Thanks.
joe42
Re: failed to open ripped Blu-ray file at 1.7.0
#2 Post by joe42 » Sun Jan 01, 2012 7:11 am
Try ripping the disc directly with MakeMKV, and see if it works or gives an error.
tomokatsu
#3 Post by tomokatsu » Mon Jan 02, 2012 1:42 pm
I tried to rip directly with MakeMKV 1.7.0, then rip was successfully.
Problem was solved. thank you very much :D
Also, I was updated AnyDVD HD to 6.9.1.0. then file read was successfully.
Maybe, previous AnyDVD HD version was buggy.
Thanks joe42 san :D
Marcello
#4 Post by Marcello » Fri Aug 04, 2023 6:54 am
tomokatsu wrote: Sun Jan 01, 2012 5:52 am Hi.
Thanks.
same problem with version 1.17.4
