Help with these Errors
Loiselle313
#1 Post by Loiselle313 » Fri May 30, 2025 11:36 pm
I'm trying to rip Guardians of the Galaxy Vol. 2 4K UHD. This is the 3rd copy I own, and all 3 have the same ripping issues, on different machines and drives.
I copied the error notes, so maybe they can point to something that's happening here that someone can help me out with.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00040.m2ts' at offset '31157907456'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '31157907456'
Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/00040.m2ts' at offset '31178489856'
Error 'OS error - The volume for a file has been externally altered such that the opened file is no longer valid' occurred while reading '\Device\CdRom1' at offset '31178489856'
Failed to save title 0 to file D:/Blu-ray Rips/MARVEL'S GUARDIANS OF THE GALAXY VOL. 2_t00.mkv
Encountered 10 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Re: Help with these Errors
#2 Post by MartyMcNuts » Mon Jun 02, 2025 1:46 am
The drive is having trouble reading a section of the disc and is trying so hard to read it, it is running out of juice and loses connection. The best thing you can do is clean the disc before trying again. Sometimes, trying the disc in another drive can also help.
