How do you burn a disc once you have made a back up?
wilberforce55
#1 Post by wilberforce55 » Sat Dec 31, 2011 5:08 am
Hi all
New to this forum.
For Christmas i got a copy of Rio 3d,and in typical fox fashion have found it is region coded. So thought i would make a back up and strip the region coding so i could play on my BR player.
I have successfully created the back-up using MakeMKV back up feature, and found the file structure closely resembles the original (except rather than Certificate there is a MakeMKV file), was wondering if someone could point me as to how to burn the files back o a BD-R. Do i just use Toast or a burning program, or is there a bun function in MaleMKV to do it?
I have searched the FAQs and Forums and can't find the answer
BlackDragon24
Re: How do you burn a disc once you have made a back up?
#2 Post by BlackDragon24 » Sat Dec 31, 2011 4:27 pm
wilberforce55 wrote:Hi all
New to this forum.
ImgBurn is my method of choice for all things burning. Free and it works every time.
setarip_old
#3 Post by setarip_old » Sun Jan 01, 2012 5:18 am
@wilberforce55
Hi!
Based on your asking about "Toast", I presume you have a Mac. If so, you won't be able to use the suggested IMGBurn, as it's not Mac-compatible.
I believe you'll be able to use Toast Titanium 11 after using MakeMKV to make a DECRYPTED FULL DISC backup copy of your Blu-ray on your hard drive...
BTW -Your FULL DISC copy should contain BDMV, CERTIFICATE, AND MakeMKV folders - and you should be able to dispose of the MakeMKV folder with no negative effect...
wilberforce55
#4 Post by wilberforce55 » Sun Jan 01, 2012 11:00 am
Yes i am on a MAc, will try that using Toast
wilberforce55
#5 Post by wilberforce55 » Wed Jan 18, 2012 9:18 am
I finally got my BD50gb discs form Japan and have just burnt my first BD-SL using Makemkv.
I ripped (what i though was ) a decrypted back-up, which created three folders (BDMV, Certificate and MAKEMKV) burnt the disc as per Toast's instructions, and created a copy (which comparing the size of the original and the copy was the same
However, when I went to play it in my BD player (samsung) it came up with exactly the same screen as the original saying this Blu Ray Disc is encoded for a A machine, not a B machine.
Does the decrypted back up not strip out the region coding, or have i missed something?
setarip_old wrote:@wilberforce55
Hi!
