BDR-XS07S UHD Flash
willie3204
Re: BDR-XS07S UHD Flash
Thank you very much coopervid. Though I dont see any PMs in my list
It took me a while but XS06 can't be flashed to be UHD capable. Sorry!willie3204 wrote: Sun Jun 01, 2025 2:28 am Hello, it looks like my drive is enabled for libredrive though its not loading the discs. Do I need to flash it?Code: Select all
Drive Information OS device name: /dev/sr0 Manufacturer: PIONEER Product: BD-RW BDR-XS06 Revision: 1.01 Serial number: ... Firmware date: 2015-03-24 Bus encryption flags: 13 LibreDrive Information Status: Enabled Drive platform: RS8721 Firmware name: PIONEER BDR-XS06 Firmware type: Original (unpatched) Firmware version: 1.01 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
willie3204
Oh. OK
Thank you for trying
espinoza
Thank you. Where can I find the tutorial referenced in the message? Thanks!Coopervid wrote: Sun Jun 01, 2025 2:34 amPM sent.espinoza wrote: Sat May 31, 2025 5:38 pm Hi All,
I've got this drive:
Could anyone help me out with info on if / how this is patchable for UHD?Code: Select all
Drive Information Manufacturer: PIONEER Product: BD-RW BDR-XS07 ...
Many thanks![]()
I have sent a wrong link. New one sent.espinoza wrote: Sun Jun 01, 2025 10:56 amThank you. Where can I find the tutorial referenced in the message? Thanks!Coopervid wrote: Sun Jun 01, 2025 2:34 amPM sent.espinoza wrote: Sat May 31, 2025 5:38 pm Hi All,
Many thanks![]()
espinoza
Thank you! all worked perfectly, managed to use MakeMKV to back up a disc. Is there any software that can directly play the 4K UHD disc directly - preferably on a Mac, if not, on Windows?
ghanima2000
Is it possible to use my drive for 4k Discs?
Revision: 1.00
Serial number:
Firmware date: 2019-01-07
Highest AACS version: 65
Drive platform: RS8E20
Firmware version: 1.00
Thanks in advance!
Revision: 1.00
Serial number:
Thanks in advance!
PM sent.ghanima2000 wrote: Wed Jun 04, 2025 6:01 pm Hi,
Revision: 1.00
Serial number:
Thanks in advance!
ghanima2000
Thanks Coopervid, worked perfectly!
AndrewB4
Thanks so much for helping everyone out. Can I get a firmware for my BDR-XS07?
OS device name: F:
Revision: 1.04
Serial number: ...
Firmware date: 2024-10-09
Highest AACS version: 78
Drive platform: Pioneer RS8E20
Firmware version: GENE-
Your firmware is too new and encrypted. You need to wait until mike enables flashing for it.AndrewB4 wrote: Fri Jun 06, 2025 7:50 pm Thanks so much for helping everyone out. Can I get a firmware for my BDR-XS07?Code: Select all
Drive Information OS device name: F: Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-XS07 Revision: 1.04 Serial number: ... Firmware date: 2024-10-09 Bus encryption flags: 13 Highest AACS version: 78 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8E20 Firmware version: GENE
DC-2187
Hello
Is this drive able to be flashed?
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: SEDL099912UC
Firmware date: 2017-06-22
Highest AACS version: 72
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
Revision: 3.10
PM sent.DC-2187 wrote: Mon Jun 09, 2025 7:00 pm Hello
Revision: 3.10
n4asp
Can someone provide instructions for flashing my XS07?
Revision: 1.01
Serial number:
Firmware date: 2020-09-03
Highest AACS version: 77
Revision: 1.01
Serial number:
PM sent.n4asp wrote: Fri Jun 13, 2025 9:28 pm Hello,
Revision: 1.01
Serial number:
