Ultimate UHD Drives Flashing Guide Updated 2025
DC-2187
Post by DC-2187 »
Just to clarify if I'm buying a Pioneer drive that is a 4k model and would not need to be flashed and was made in 2023..that would still work with makemkv?
DC-2187 wrote:
Fri May 30, 2025 9:03 pm
Not for UHD currently. Only Pioneer drives with firmware prior to December 2022 are/can be made UHD compatible.
Sometime in the future, those with firmware from December 2022 onwards will be able to be flashed for UHD compatibility.
DC-2187
Post by DC-2187 »
MartyMcNuts wrote:
Sat May 31, 2025 12:23 am
Oh I see thanks for the response. I guess I will hold off. I figured maybe a 4k model drive would work but oh well. Good thing I asked before buying
DC-2187 wrote:
Sat May 31, 2025 12:31 am
The issue is, to be able to rip UHD discs, LibreDrive mus be enabled for the drive and any Pioneer (UHD/Non UHD) with firmware from Dec 2022 onwards cannot currently have LibreDrive enabled. This is expected to happen sometime in the future.
qnixgamer
Post by qnixgamer »
OS device name: E:
Current profile: CD-ROM
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E102
Serial number: ,,,
Firmware date: 2023-04-20
Firmware version: ID26
Is there way to make drive UHD compatible?
Packers948
Post by Packers948 »
Hi - Please let me know what LG firmware would be best for this drive WH16NS46. Thank you
MakeMkv information as below.
OS device name: G:
Product: BD-RE WH16NS46
Revision: 1.05
Serial number: NA
Firmware date: 2122-01-14 11:38
Highest AACS version: 77
qnixgamer wrote:
Sat May 31, 2025 5:59 pm
OS device name: E:
Manufacturer: ASUS
Revision: E102
Serial number: ,,,
Not at this time. Firmware is too new. You need to wait until some time in the future when Pioneer drives with firmware from December 2022 onwards are supported.
Jimothy
Post by Jimothy »
Hi there,
Ive been reading through the board here and would like to ask somebody if they know whether or not my drive can be successfully flashed?
OS device name: /dev/rdisk5
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BU14
Serial number: 00000000000
Firmware date: 2121-06-21 13:30
Bus encryption flags: 1F
Highest AACS version: 72
that's the info from MakeMKV info panel, it seems as if I have firmware from a hundred years in the future?!?!? some help would be most appreciated, thanks
Jimothy wrote:
Tue Jun 03, 2025 8:56 pm
Hi there,
Revision: BU14
Yes, MakeMKV shows the firmware date as 2121 instead of 2021.
Yeah, you can flash it to BU40N 1.03-MK.
tyme2tb
Post by tyme2tb »
Would the below be able to be flashed to do UHD
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.10
Serial number: xxxxxxxxxxx
Firmware date: 2013-09-10
Bus encryption flags: 13
Drive platform: RS8600
Firmware version: 1.10/ID60
nathanm5764
Post by nathanm5764 »
Hi, I appear to have a newish (2020) drive with oldish (2017) firmware, could you advise on what (if any) firmware I can flash with to get LibreDrive functionality?
OS device name: E:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: T*********L
Firmware date: 2017-04-18
Highest AACS version: 12
Firmware version: ID22
Sam88
Post by Sam88 »
I just purchased a Verbatim 43888, because it was frequently suggested.
Can you tell me if it is flashable and which Firmware to use?
OS device name: E:
Product: BDDVDRW GGC-H20L
Revision: 1.02
Serial number: ...
Firmware date: 2007-12-27 12:34:56
Status: Possible, might be supported in future, but not likely soon
Drive platform: RS1013
Firmware version: 1.02-
Sam88 wrote:
Tue Jun 10, 2025 7:00 pm
OS device name: E:
Revision: 1.02
Serial number: ...
Not possible.
tyme2tb wrote:
Wed Jun 04, 2025 1:00 am
OS device name: G:
Revision: 1.10
PM sent.
nathanm5764 wrote:
Fri Jun 06, 2025 9:49 am
OS device name: E:
Manufacturer: ASUS
Revision: 1.10
PM sent.
