MKV Files and HDR
leosantare
MKV Files and HDR
#1 Post by leosantare » Sat May 03, 2025 5:10 am
When I rip a 4K UHD blu-ray in makemkv, does the mkv file actually have HDR? For example, the picture appears exactly the same in VLC player if HDR is enabled or not in Windows. When I enable HDR in Windows, I can see the change in Windows. Plus, my display briefly shows the signal has changed to HDR mode. However, there is no difference when playing a mkv file in VLC.
Re: MKV Files and HDR
#2 Post by dcoke22 » Sat May 03, 2025 1:07 pm
If you look at the .mkv file with MediaInfo, the video section will list if the file has Dolby Vision and/or HDR10. For example, here's a movie with only HDR10:
Video
ID in the original source medium         : 4113 (0x1011)
HDR format                               : SMPTE ST 2086, HDR10 compatible
Duration                                 : 1 h 57 min
Bit rate                                 : 50.8 Mb/s
Bits/(Pixel*Frame)                       : 0.256
Stream size                              : 41.7 GiB (93%)
Maximum Content Light Level              : 1376 cd/m2
Maximum Frame-Average Light Level        : 731 cd/m2
and here's an example with both:
Video
HDR format                               : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Duration                                 : 1 h 47 min
Bit rate                                 : 100 Mb/s
Bits/(Pixel*Frame)                       : 0.504
Stream size                              : 75.2 GiB (95%)
Maximum Content Light Level              : 7130 cd/m2
Maximum Frame-Average Light Level        : 545 cd/m2
I don't really use Windows or VLC so I can't really make suggestions about them.
leosantare
#3 Post by leosantare » Sat May 03, 2025 11:37 pm
Okay, well hopefully someone can help with Windows and VLC.
leosantare
#4 Post by leosantare » Sun May 04, 2025 9:44 pm
Why isnt there a difference if hdr is enabled in windows or not when playing a mkv in vlc?
Ezatoka
#5 Post by Ezatoka » Mon May 05, 2025 9:57 am
I don't know for sure, but maybe VLC automatically issues some tonemapping if it finds a HDR source with a non-HDR display.
leosantare
#6 Post by leosantare » Tue May 06, 2025 12:39 am
I'm not sure what you mean by that. I know my display is not in HDR unless I enable it in Windows. Like I said, there is no difference in the picture if HDR is enabled in Windows. I understand VLC supports HDR and dcoke22 confirmed that mkv files contain HDR.
Mr. Red
#7 Post by Mr. Red » Fri May 09, 2025 10:08 am
You could try MPC-HC with MPC Video Renderer instead of VLC.
smol_birb
#8 Post by smol_birb » Fri May 30, 2025 8:06 pm
leosantare wrote: Tue May 06, 2025 12:39 am I'm not sure what you mean by that. I know my display is not in HDR unless I enable it in Windows. Like I said, there is no difference in the picture if HDR is enabled in Windows. I understand VLC supports HDR and dcoke22 confirmed that mkv files contain HDR.
Windows will have the option to enable HDR, even if the display doesn't support HDR. Does your display support HDR?
Mutato
#9 Post by Mutato » Fri Jun 06, 2025 12:10 pm
MPC-HC player with madVR Renderer and you need display with HDR support, check hardware specifications, user manual.
leosantare
#10 Post by leosantare » Sun Jul 06, 2025 3:26 am
When I had a display that did not support HDR, I could not enable HDR in Windows. Now, that I have a display that supports HDR, I can enable HDR in Windows.
Okay, I will try MPC-HC with madVR.
Thank you,
