ASUS SBW-06D2X-U
Hamiltonblue
Re: ASUS SBW-06D2X-U
Running now
Thank You Billy!!!
Thank You Billy!!!
maily.spamy
I have this drive:
Can I update the new firmware from ASUS to enable M-Disc and stay it LibreDrive enabled?
I have this drive:
OS device name: E:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.03
Serial number: ...
Firmware date: 2016-12-16
Drive platform: RS8510
Firmware version: 1.03/ID22
revere
Hi Coopervid,Coopervid wrote: Sun Feb 16, 2025 6:09 pmPM sent.revere wrote: Sun Feb 16, 2025 4:51 pm Hi coopervid, can you please assist in getting Libredrive firmware for my drive?
Stasjon informasjon
Operativsystemets stasjons navn: D:
Produsent: ASUS
Produkt: SBC-06D2X-U
Revisjon: 1.10
Serienummer:
Firmware dato: 2017-04-18
Krypteringsflagg for databus: 1B
Drive platform: RS8591
Firmware version: 1.10/ID22
the firmware you provided was not accepted by the drive. Was the wrong firmware sent accidentally?
See error message and device information here:
Your drive is not a BD writer but a BD combo and can‘t be flashed.
revere
Thanks for the update. You had identified this drive as one suppported earlier, but this seems to be wrong then. Seems like I have to look for a new drive to get the features I need.Coopervid wrote: Sat May 24, 2025 4:23 pm Your drive is not a BD writer but a BD combo and can‘t be flashed.
GoesWithEverything
Hi there,
I also have this drive. I am hoping to enable LibreDrive for this writer. Is there anything I need to do to make this happen?
OS device name: E:
Manufacturer: ASUS
Revision: 1.10
Serial number: [Redacted, unless needed]
Firmware date: 2017-04-18
Firmware version: ID22
I was quite in a hurry since I'm on vacation and travelling. Firmware 8591 identifies it as a combo and I should have noticed that. Sorry!revere wrote: Sun May 25, 2025 3:53 pmThanks for the update. You had identified this drive as one suppported earlier, but this seems to be wrong then. Seems like I have to look for a new drive to get the features I need.Coopervid wrote: Sat May 24, 2025 4:23 pm Your drive is not a BD writer but a BD combo and can‘t be flashed.
PM sent.GoesWithEverything wrote: Sun May 25, 2025 11:03 pm Hi there,
Drive Information OS device name: E: Manufacturer: ASUS Product: SBW-06D2X-U Revision: 1.10 Serial number: [Redacted, unless needed] Firmware date: 2017-04-18 Bus encryption flags: 1B LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8511 Firmware version: ID22 No disc inserted
kaulvirus
I am in the same boat. Wondering if I could be helped as well?
OS device name: E:
Manufacturer: ASUS
Revision: A102
Serial number: MOAN
Firmware date: 2121-06-28 13:41
Bus encryption flags: 1F
OS device name: E:
Manufacturer: ASUS
Revision: A102
Serial number: MOAN
ashahzadpk
OS device name: I:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
please help. thanks in advance
Still waiting for response Please help
OS device name: I:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
Your drive looks to be same as the one mentioned in this post: https://forum.makemkv.com/forum/viewtopic.php?p=173318#p173318kaulvirus wrote: Fri May 30, 2025 6:39 pm Hi,
OS device name: E:
Manufacturer: ASUS
Revision: A102
Serial number: MOAN
The drive platform is MT1959, which means the drive's internals are the same as other LG drives. As such, you can flash it yourself using the tools and instructions in the Ultimate UHD Drives Flashing Guide. As Billycar11 says in the referenced post, follow the instructions for the LG BU40N with encrypted firmware.
kaulvirus
Thanks so much!dcoke22 wrote: Sat May 31, 2025 3:41 pmYour drive looks to be same as the one mentioned in this post: https://forum.makemkv.com/forum/viewtopic.php?p=173318#p173318kaulvirus wrote: Fri May 30, 2025 6:39 pm Hi,
OS device name: E:
Manufacturer: ASUS
Revision: A102
Serial number: MOAN
zShionz
Hi, I have this Blu-ray and I would like to make it compatible with UHD discs.
OS device name: H:
Manufacturer: ASUS
Revision: 1.10
Serial number:
thank you.
OS device name: H:
Manufacturer: ASUS
Revision: 1.10
Serial number:
thank you.
ashahzadpk
Still waiting Please Helpashahzadpk wrote: Sat May 31, 2025 5:30 am Drive Information
OS device name: I:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
PM sent.zShionz wrote: Sun Jun 01, 2025 4:11 pm Hi, I have this Blu-ray and I would like to make it compatible with UHD discs.
OS device name: H:
Manufacturer: ASUS
Revision: 1.10
Serial number:
thank you.
