I just need to know what information is needed and how to collect the log or whatever else is required. Thanks
Issues with "Number 23" DVD
hwrd69
I had an older issue of this DVD and tried ripping and backing up, with no success. I ordered a new copy and it plays fine in the player, but I still get a failure when either ripping or backing up. I would like to get some help to either understand what is wrong and how to fix it, or to give up
Re: Issues with "Number 23" DVD
Copy & paste the output in the bottom of the MakeMKV window into a post here on the forum.
bradycl98321
Did you ever get this figured out? I am having a similar problem with the same DVD.
Can you post your MakeMKV output from trying to rip this DVD?bradycl98321 wrote: Fri Apr 04, 2025 2:51 am Did you ever get this figured out? I am having a similar problem with the same DVD.
solstyce9
FWIW, I also was unable to rip my Number 23 DVD, with MakeMKV or AnyDVD, with my DVD drive or my Blu-ray drive. MakeMKV gives me a media read error, but the disc appears immaculate. I'm assuming a problem in the mastering process, either accidental or intentional, but I'm not wasting my time or money to try to figure it out.
I would appreciate hearing if anyone out there has successfully ripped this movie and if so, more details on your DVD to see if there's a particular version of this movie that is easier to rip.
BerryUnusual
I'm having the same issues with the same disk. I made sure the disk was clean and free of scratches.
I've pasted the log output below in hopes of helping myself and others in case someone is able to figure out why this can't be made into an MKV.
DEBUG: Code 100864256 at mSHv1hk}.MpL;_ZYj<:213132445
DEBUG: Code 100864256 at mSHv1hk}.MpL;_ZYj<:121262302
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '0'
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading 'BD-ROM HL-DT-ST BDDVDRW CH12LS28 1.02 K98B6N43830' at offset '0'
DEBUG: Code 3 at X_Q`2"KJuGp@<O:29400232
DEBUG: Code 3 at X_Q`2"KJuGp@<O:29393631
DEBUG: Code 0 at t9=xZ^1%BBy>K|^ Y:121263245
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_04_1.VOB' at offset '0'
DEBUG: Code 4 at X_Q`2"KJuGp@<O:29400232
DEBUG: Code 4 at X_Q`2"KJuGp@<O:29393631
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '0'
DEBUG: Code 5 at X_Q`2"KJuGp@<O:29400232
DEBUG: Code 5 at X_Q`2"KJuGp@<O:29393631
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_06_1.VOB' at offset '0'
DEBUG: Code 6 at X_Q`2"KJuGp@<O:29400232
DEBUG: Code 6 at X_Q`2"KJuGp@<O:29393631
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_07_1.VOB' at offset '0'
DEBUG: Code 7 at X_Q`2"KJuGp@<O:29400232
DEBUG: Code 7 at X_Q`2"KJuGp@<O:29393631
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_08_1.VOB' at offset '0'
DEBUG: Code 8 at X_Q`2"KJuGp@<O:29400232
DEBUG: Code 8 at X_Q`2"KJuGp@<O:29393631
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_09_1.VOB' at offset '0'
DEBUG: Code 9 at X_Q`2"KJuGp@<O:29400232
DEBUG: Code 9 at X_Q`2"KJuGp@<O:29393631
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_10_1.VOB' at offset '0'
DEBUG: Code 10 at X_Q`2"KJuGp@<O:29400232
DEBUG: Code 10 at X_Q`2"KJuGp@<O:29393631
DEBUG: Code 118095996 at &zUO>=0yYM*;qG%t8r#+X\b:29394183
DEBUG: Code 0 at &zUO>=0yYM*;qG%t8r#+X\b:121263590
DEBUG: Code 0 at 7#MR{@HBo.ez7ec]o9Uy:29394689
DEBUG: Code 3221225649 at QpU860LV{}|}B]j|,_$%hs :29394919
DEBUG: Code 3221225649 at &zUO>=0yYM*;qG%t8r#+X\b:213130145
DEBUG: Code 3221225480 at QpU860LV{}|}B]j|,_$%hs :121262509
DEBUG: Code 3221225480 at &zUO>=0yYM*;qG%t8r#+X\b:29394183
DEBUG: Code 0 at g|Td]xYm%Lw_)*:29397104
Cells 1-2 were removed from title start
Cells 13-13 were removed from title end
Title #1 was added (10 cell(s), 0:08:22)
Cells 2-2 were removed from title end
Title #2 was added (1 cell(s), 0:01:51)
Title #3 was added (1 cell(s), 0:00:42)
Title #4 was added (1 cell(s), 0:00:23)
Title #5 was added (1 cell(s), 0:00:26)
Title #6 was added (1 cell(s), 0:00:29)
Title #7 was added (1 cell(s), 0:00:27)
Title #8 was added (1 cell(s), 0:00:54)
Title #9 was added (1 cell(s), 0:00:39)
Title #10 was added (1 cell(s), 0:00:32)
Title #11 was added (1 cell(s), 0:00:53)
Title #12 was added (1 cell(s), 0:00:49)
Title #13 was added (1 cell(s), 0:02:50)
Cells 25-25 were removed from title end
Title #14 was added (24 cell(s), 0:24:55)
Title #15 was added (2 cell(s), 0:00:18)
Title #16 was added (2 cell(s), 0:00:30)
Title #17 was added (2 cell(s), 0:00:44)
Title #18 was added (2 cell(s), 0:01:17)
Title #19 was added (2 cell(s), 0:01:49)
Title #20 was added (2 cell(s), 0:02:33)
Title #21 was added (2 cell(s), 0:02:00)
Title #22 was added (2 cell(s), 0:01:08)
Title #23 was added (2 cell(s), 0:01:11)
Title #24 was added (2 cell(s), 0:00:46)
Title #25 was added (2 cell(s), 0:00:42)
Title #26 was added (2 cell(s), 0:02:52)
Title #27 was added (2 cell(s), 0:00:22)
Title #28 was added (2 cell(s), 0:00:39)
Title #29 was added (2 cell(s), 0:01:46)
Title #30 was added (2 cell(s), 0:00:53)
Title #31 was added (2 cell(s), 0:02:35)
Title #32 was added (2 cell(s), 0:01:09)
Title #33 was added (2 cell(s), 0:01:12)
IFO file for VTS #2 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Title #37 in broken titleset was skipped
Title #38 in broken titleset was skipped
Title #39 in broken titleset was skipped
Title #40 in broken titleset was skipped
Title #41 in broken titleset was skipped
Title #42 in broken titleset was skipped
Title #43 in broken titleset was skipped
Title #44 in broken titleset was skipped
Title #45 in broken titleset was skipped
Title #46 in broken titleset was skipped
Title #47 in broken titleset was skipped
Title #48 in broken titleset was skipped
Title #49 in broken titleset was skipped
Title #50 in broken titleset was skipped
Title #51 in broken titleset was skipped
Title #52 in broken titleset was skipped
Title #53 in broken titleset was skipped
Title #54 in broken titleset was skipped
Title #55 in broken titleset was skipped
Title #56 in broken titleset was skipped
Title #57 in broken titleset was skipped
Title #58 in broken titleset was skipped
Title #59 in broken titleset was skipped
Title #60 in broken titleset was skipped
Title #61 in broken titleset was skipped
Title #62 in broken titleset was skipped
Title #63 in broken titleset was skipped
Title #64 in broken titleset was skipped
Title #65 in broken titleset was skipped
Title #66 in broken titleset was skipped
Title #67 in broken titleset was skipped
Title #68 in broken titleset was skipped
Title #69 in broken titleset was skipped
Title #70 in broken titleset was skipped
Title #71 in broken titleset was skipped
Title #72 in broken titleset was skipped
Title #73 in broken titleset was skipped
Title #74 in broken titleset was skipped
Title #75 in broken titleset was skipped
Title #76 in broken titleset was skipped
Title #77 in broken titleset was skipped
Title #78 in broken titleset was skipped
Title #79 in broken titleset was skipped
Title #80 in broken titleset was skipped
Title #81 in broken titleset was skipped
Title #82 in broken titleset was skipped
Title #83 in broken titleset was skipped
Title #84 in broken titleset was skipped
Title #85 in broken titleset was skipped
Title #86 in broken titleset was skipped
Title #87 in broken titleset was skipped
Title #88 in broken titleset was skipped
Title #89 in broken titleset was skipped
Title #90 in broken titleset was skipped
Title #91 in broken titleset was skipped
Title #92 in broken titleset was skipped
Title #93 in broken titleset was skipped
Title #94 in broken titleset was skipped
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 12288, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 32768, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 14336, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 8192, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 20480, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 34816, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 14336, attempting to work around-
solstyce9
I ran across another The Number 23 today and decided to give it a try. It attempted to workaround but the list of titles it gave to rip were all extra items, not the main feature. This is the unrated version from Infini Film.dcoke22 wrote: Mon Apr 07, 2025 1:08 pmCan you post your MakeMKV output from trying to rip this DVD?bradycl98321 wrote: Fri Apr 04, 2025 2:51 am Did you ever get this figured out? I am having a similar problem with the same DVD.
Here is the debug log
MakeMKV v1.18.3 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\-redacted-/MakeMKV_log.txt
DEBUG: Code 2 at 0^_f5JgS;8{MMS!bqY&\./ :121261704
DEBUG: Code 3221225486 at 0^_f5JgS;8{MMS!bqY&\./ :121261727
DEBUG: Code 3221225486 at tAJ\A2rZbLQ#rf]ga[J4:213130582
Using LibreDrive mode (v02.1 id=F39BF9BC17BE)
DEBUG: Code 100864261 at mSHv1hk}.MpL;_ZYj<:213132445
DEBUG: Code 100864261 at mSHv1hk}.MpL;_ZYj<:121262302
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '0'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE PIONEER BD-RW BDR-UD03 1.14 AFDL408072WL' at offset '0'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_04_1.VOB' at offset '0'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '0'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_06_1.VOB' at offset '0'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_07_1.VOB' at offset '0'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_08_1.VOB' at offset '0'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_09_1.VOB' at offset '0'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_10_1.VOB' at offset '0'
Title #2 has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #16 has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17 has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 has length of 109 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #22 has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #23 has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24 has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25 has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #27 has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #28 has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #29 has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #30 has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #32 has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #33 has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Messages like this:
mean the optical drive is having trouble reading part of the disc. The standard advice is to gently clean the disc and try again.
gkar_of_narn
I tried the DVD in manual mode and was able to see 3 titles. 1 hour 37 minutes,1 hour 41 minutes and the third was 1 hour 37 minutes. All three failed when I tried ripping them in manual mode. The farthest I got was with Handbrake where it successfully ripped about 50 minutes (tried all 3 titles) and then "encode failed" message appeared. This was a brand new DVD.
