I have tried and retried to RIP the movie: "The Day The Earth Blew Up - A Looney Tunes Movie" and I keep getting an error:
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading 'BD-RE ASUS BW-16D1HT 3.10 KLQM7TF1909' at offset '32768'
I have unplugged my Asus External DVD Ripper, rebooted my Windows 11 PC, wiped down the disc a couple times, but I keep getting the same error. I have tried using other DVDs, but they work just fine. Any ideas on what I can do to resolve this? Thank you.
MakeMKV v1.18.1 win(x64 release)
Windows 11 Pro, version 24H2, OS build 26100.4202
Getting Error When Trying to RIP: The Day The Earth Blew Up - Looney Tunes Movie
JulesKeeper
JulesKeeper
Re: Getting Error When Trying to RIP: The Day The Earth Blew Up - Looney Tunes Movie
UPDATE: Since I haven't received any responses and I believe I have exhausted troubleshooting methods, I'm returning the DVD to Amazon for a replacement. Hopefully, this one will work.
JulesKeeper
I received the new DVD for "The Day the Earth Blew Up" (Looney Tunes Movie) and I'm still unable to RiP this DVD because I'm getting the same error:
There doesn't appear to be any scratches on the DVD. Could this be an issue where MakeMKV is unable to decrypt the content?
Any help to Rip this movie would be appreciated.
JulesKeeper
Here is the Debug Log . . . please let me know if any additional information will help troubleshoot this issue. Thank you.
Debug log started at Sat May 31 02:41:46 2025 , written by MakeMKV v1.18.1 win(x64-release)
001005:0000 MakeMKV v1.18.1 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\Jules/MakeMKV_log.txt
DEBUG: Code 3 at u%~+41nw7Z$>\(rT@7Hdjpjz:29395310
SDF v098: ASUS_BW-16D1HT_3.10_211901041014_KLQM7TF1909
001003:0020 DEBUG: Code 3221225653 at Ch]p)5tP.:IK>c#<:213130559
001003:0020 DEBUG: Code 3221225629 at Ch]p)5tP.:IK>c#<:213130559
001003:0020 DEBUG: Code 3221225629 at A%oe?*<o<t0n{T~IVR:121263429
001003:0020 DEBUG: Code 3221225629 at A%oe?*<o<t0n{T~IVR:121262302
002003:0000 Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading 'BD-RE ASUS BW-16D1HT 3.10 KLQM7TF1909' at offset '1048576'
002003:0000 Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading 'BD-RE ASUS BW-16D1HT 3.10 KLQM7TF1909' at offset '65536'
001012:0000 udf: UDF mount: reading in reserve VDS extent
002003:0000 Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading 'BD-RE ASUS BW-16D1HT 3.10 KLQM7TF1909' at offset '98304'
001012:0000 udf: UDF mount: error reading volume space
001003:0020 DEBUG: Code 3221225664 at Ch]p)5tP.:IK>c#<:213130559
001003:0020 DEBUG: Code 3221225664 at A%oe?*<o<t0n{T~IVR:121263429
001003:0020 DEBUG: Code 3221225664 at A%oe?*<o<t0n{T~IVR:121262302
002003:0000 Error 'OS error - This device does not exist' occurred while reading 'BD-RE ASUS BW-16D1HT 3.10 KLQM7TF1909' at offset '32768'
001003:0020 DEBUG: Code 0 at ;:,!3ae,:z|RC`o._<A:121261773
001003:0020 DEBUG: Code 3221225664 at e!/TsMgD>)UEE`0S:121267293
Application exited at Sat May 31 02:42:22 2025-
How is your drive powered? Is it powered via USB or does it have a separate power supply plugged into the wall?
If it is powered via USB, make sure both USB-A plugs are plugged into high powered ports.
An error like:
usually means the operating system noticed the drive disappeared while it was being used. In the case of USB powered drives, it is possible for MakeMKV to spin the drive fast enough that the drive needs more power than the USB port can provide. When this happens, the drive 'reboots' in the middle of a rip, ruining it.
Ironically, this is more likely to happen on a very clean disc. MakeMKV slows down the read rate with discs that it has trouble reading correctly since reading slower often improves the chances of getting a good rip. On very clean discs, MakeMKV can go as fast as the drive can go, sometimes exceeding the power available to the drive.
An error like:
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading 'BD-RE ASUS BW-16D1HT 3.10 KLQM7TF1909' at offset '1048576'Ironically, this is more likely to happen on a very clean disc. MakeMKV slows down the read rate with discs that it has trouble reading correctly since reading slower often improves the chances of getting a good rip. On very clean discs, MakeMKV can go as fast as the drive can go, sometimes exceeding the power available to the drive.
JulesKeeper
Thank you for your response. This was very helpful
