AACS v82 Blu-ray Disc dump submission
cc175493
Post by cc175493 »
Hi everyone,
I’m trying to backup a Blu-ray disc using MakeMKV, but I keep getting the error: “This disc uses a newer version of AACS protection” and "The volume key is unknown for this disc - video can't be decrypted".
There are four disc with the same issue. Each disc has created an AACS dump file (attached for reference).
Below are the drive info and makemkv output from one of the disc:
Drive information and disk information:
Manufacturer: PIONEER
Product: BD-RW BDR-XS08U
Revision: 1.03
Serial number:
Firmware date: 2024-10-09
Highest AACS version: 82
Drive platform: Pioneer RS9621
Firmware version: ID69
Disc Information
Label: BD_VIDEO
Timestamp: 2025-04-03 15:00:09
Protection: AACS v82
Data capacity: 37.97 Gb
Disc type: BD-ROM
Number of layers: 2
Output from MakeMKV:
MakeMKV v1.18.1 darwin(arm64-release) started
Optical drive "BD-RE PIONEER BD-RW BDR-XS08U 1.03" opened in OS access mode.
Backing up disc into folder "/Users/      /Movies/backup/BD_VIDEO"
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?...
Saved AACS dump file as /Users/      /Library/MakeMKV/MKB_v82_BD_VIDEO_6852.tgz
Backup failed
Any guidance would be greatly appreciated! Happy to provide additional details if needed.
Thanks in advance!
MKB_v82_BD_VIDEO_115C.tgz
(106.53 KiB) Downloaded 4 times
MKB_v82_BD_VIDEO_142A.tgz
(107.67 KiB) Downloaded 4 times
(118.28 KiB) Downloaded 4 times
cc175493
Re: AACS v82 Blu-ray Disc dump submission
Post by cc175493 »
And the last AACS dump file of the batch.
Any help and guidance will be much appreciated.
Thank you.
MKB_v82_BD_VIDEO_8AD0.tgz
(108.02 KiB) Downloaded 3 times
ganbatane
Post by ganbatane »
Sorry to piggyback on OP. I'm in the same boat. I've been downloading updated keydb files every day for a week, no dice. So trying the forums.
MKB_v82_デザインあneo_48CE
I'm not sure if I should be using the english keydb or the japanese, so I've been trying both each day.
attached:
MKB_v82_デザインあneo_48CE.tgz
Thank you! Onegaishimasu!
(89.45 KiB) Downloaded 1 time
