Cars 2 Problem.
headhot
Cars 2 Problem.
Post by headhot » Sat Dec 31, 2011 4:50 pm
I'm trying to back up Cars 2 BD with makemkv on OSX and I'm getting this error:
MakeMKV v1.7.0 darwin(x86-release) started
Debug logging enabled, log will be saved as MakeMKV_log.txt
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5690H 4AH5" opened in DASPI v1.3 mode.
Optical drive "BD-RE MATSHITA BD-MLT UJ-220S 1.00" opened in DASPI v1.3 mode.
Backing up disc into folder "~/Movies/backup/CARS2_D1"
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00948.m2ts' at offset '119406592'
DEBUG: Code 0 at 7s{V$<x01Vlnz5j 'i^s:121267661
DEBUG: Code 0 at 7s{V$<x01Vlnz5j 'i^s:121274055
Backup failed
crowfax
Re: Cars 2 Problem.
Post by crowfax » Sat Dec 31, 2011 6:07 pm
This error:
Literally means the drive can't read the disc. There are no copy protections that can cause this. This leaves you with 2 possibilities:
1. The disc you are trying to ripped is damaged, dirty or poorly manufactured.
2. The drive you are using to rip the disc is failing and mechanically unsound.
The first thing you should do is return the disc for a new one and get a new one to test.
