Which parts of qt are needed?
ggking7
Post by ggking7 »
Which parts of qt are needed for makemkv? Gentoo recently split qt into many different packages and I'd like to update the makemkv ebuild to specify the needed ones.
Re: Which parts of qt are needed?
Post by mike admin »
noone here is familiar with gentoo. where can we get list of packages and download package contents?
Also, if you're maintaining packages/build please create a topic here with links to your page and I'll convert it to sticky.
ggking7
Post by ggking7 »
Here is the Gentoo bug with the makemkv ebuild:
http://bugs.gentoo.org/show_bug.cgi?id=280347
The following is a list of qt modules. Could you guess as to which are required? I can test.
qt-assistant
qt-core
qt-dbus
qt-demo
qt-embedded
qt-gui
qt-multimedia
qt-opengl
qt-phonon
qt-qt3support
qt-script
qt-sql
qt-svg
qt-test
qt-webkit
qt-xmlpatterns
qt-gui only. Also please note that "<cstdio>" bug was fixed in 1.4.7 so the patch is not needed.
ggking7
Post by ggking7 »
The updated ebuild has been posted. Thank you for the info.
