Program reads data faster than it can write to disk
RealityRipple
Post by RealityRipple » Fri Dec 30, 2011 9:53 pm
I get this message a lot whenever I use an ISO as a source. Most drives read faster than they write; is this really a necessary message?
joe42
Re: Program reads data faster than it can write to disk
Post by joe42 » Fri Dec 30, 2011 11:30 pm
It is good to know in some situations, where the user might be able to do something about it.
Although I would rather MakeMKV just displayed the burst read and write rates in the "Information" section, rather than just the average Read rate that it displays now. Then the message would not be necessary, since you could plainly see the burst read and write speeds.
Romansh
Post by Romansh » Sat Dec 31, 2011 4:39 pm
What the message means is that your optical drive is able to read data faster than MakeMKV can write it to your hard drive - though obviously, in the case of an ISO image, you're not really ripping from an optical disc…
RealityRipple
Post by RealityRipple » Sat Dec 31, 2011 4:46 pm
Romansh wrote:What the message means is that your optical drive is able to read data faster than MakeMKV can write it to your hard drive - though obviously, in the case of an ISO image, you're not really ripping from an optical disc…
Hence the message should probably only be displayed when ripping from an optical disc.
Post by mike admin » Wed Jan 04, 2012 3:34 pm
Well, normally you do want to know why the conversion speed suddenly dropped from 33x to 7x or so...
