foxbat
#10981 Post by foxbat » Fri May 16, 2025 8:16 pm
kazuma wrote: Fri May 16, 2025 7:50 pm how is the DV performance of jellyfin? is it incorrectly?
As long as you're not transcoding it's the same as playing direct from network
staknhalo
#10982 Post by staknhalo » Fri May 16, 2025 10:25 pm
foxbat wrote: Fri May 16, 2025 11:32 am Is it normal for the DV P5 version of a given stream to be around 30% larger than the equivalent HDR10 version?
For example:
Andor.S02E04.2160p.DSNP.WEB-DL.DDPA5.1.DV.HEVC-PlayWEB.mkv: 6431381983
Andor.S02E04.2160p.DSNP.WEB-DL.DDPA5.1.HDR.HEVC-PlayWEB.mkv: 4305241410
I also notice that the hybrid P8 files people are posting are around the same size as the HDR10 versions. Is something being lost from the P5 files during that conversion?
Yes DV5 versions of titles are always/almost always encoded at higher bitrates than HDR10 versions of some files from what I've seen - I imagine it's 'spec' or 'guidelines' by Dolby for DV certification/redistribution 'can't be below/must be at certain bitrate/threshold' in order to show 'how DV is the best' - Lord knows the streamers would love to reduce bitrate/transmission costs/storage/etc as much as they can get away with.
kazuma
#10983 Post by kazuma » Fri May 16, 2025 10:36 pm
foxbat wrote: Fri May 16, 2025 8:16 pm
i want to know if the profile playback is correctly of the DV metadata?
foxbat
#10984 Post by foxbat » Sat May 17, 2025 9:53 am
kazuma wrote: Fri May 16, 2025 10:36 pm i want to know if the profile playback is correctly of the DV metadata?
That's going to depend on the device you're playing it on. On an Ugoos AM6B Plus running CPM build of CoreELEC with the Jellyfin Kodi addin, DV playback is correct.
bbeny123
#10985 Post by bbeny123 » Mon May 26, 2025 10:23 am
@RESET_9999, I have questions regarding HDR to Dolby Vision conversion and proxy encoding.
1. cm_analyze vs. Resolve for DV conversion: which produces better (more accurate) RPU?
I've generated RPU XML files using both DaVinci Resolve (following your tutorial) and cm_analyze, and noticed differences in the Level 1 metadata. The ColorEncoding sections also differ significantly:
Resolve output:
<ColorEncoding>
  <Primaries>
    <Red>0.68 0.32</Red>
    <Green>0.265 0.69</Green>
    <Blue>0.15 0.06</Blue>
  </Primaries>
  <ColorSpace>rgb</ColorSpace>
  <SignalRange>computer</SignalRange>
</ColorEncoding>
cm_analyze output:
<ColorEncoding>
  <Primaries>
    <Red>0.708 0.292</Red>
    <Green>0.17 0.797</Green>
    <Blue>0.131 0.046</Blue>
  </Primaries>
  <ColorSpace>ycbcr_bt2020</ColorSpace>
  <SignalRange>video</SignalRange>
</ColorEncoding>
Based on this and the plots below, which RPU would you consider more accurate or "better"? I've included XMLs for reference.
2. Can ProRes Profile 1 or 2 (Apple HW) be used as a proxy instead of Profile 3 with q=4 (SW)?
From my tests, Profile 2 (Apple HW) seems to have higher fidelity to the original source than Profile 3 with q=4 (SW). Even Profile 1 (Apple HW) performs surprisingly well and is quite close.
Does the profile number carry any real-world implication beyond bitrate?
Would Profile 1 (Apple HW) be good enough for proxy use, or would you still recommend suffering through Profile 2's higher bitrate and file size?
Here are some PSNR results and encoding stats:
Profile     | Encoder                | PSNR (avg) | PSNR (min) | Size    | Bitrate
P3 Q4       | SW: prores_ks          | 58.95      | 56.69      | 27.4 GB | 196 Mb/s
P1          | SW: prores_ks          | 58.96      | 53.15      | 34.3 GB | 246 Mb/s
P2 (Apple)  | HW: prores_videotoolbox| 62.82      | 58.26      | 48.8 GB | 350 Mb/s
P1 (Apple)  | HW: prores_videotoolbox| 59.05      | 55.45      | 28.9 GB | 207 Mb/s
Encoding commands:
- P3 (Q4): ffmpeg -i test.mkv -c:v prores_ks -profile:v 3 -vendor apl0 -qscale:v 4 -color_primaries bt2020 -color_trc smpte2084 -colorspace bt2020nc -pix_fmt yuv422p10le test_p3-q4.mov
- P1 (QX): ffmpeg -i test.mkv -c:v prores_ks -profile:v 1 -vendor apl0 -color_primaries bt2020 -color_trc smpte2084 -colorspace bt2020nc -pix_fmt yuv422p10le test_p1-qx.mov
- P2 (HW): ffmpeg -i test.mkv -c:v prores_videotoolbox -profile:v 2 -color_primaries bt2020 -color_trc smpte2084 -colorspace bt2020nc test_p2-hw.mov
- P1 (HW): ffmpeg -i test.mkv -c:v prores_videotoolbox -profile:v 1 -color_primaries bt2020 -color_trc smpte2084 -colorspace bt2020nc test_p1-hw.mov
PSNR commands:
- P3 (Q4): ffmpeg -r 24000/1001 -i test.mkv -r 24000/1001 -i test_p3-q4.mov -lavfi psnr="stats_file=test_p3-q4.log" -f null -
- P1 (QX): ffmpeg -r 24000/1001 -i test.mkv -r 24000/1001 -i test_p1-qx.mov -lavfi psnr="stats_file=test_p1-qx.log" -f null -
- P2 (HW): ffmpeg -r 24000/1001 -i test.mkv -r 24000/1001 -i test_p2-hw.mov -lavfi psnr="stats_file=test_p2-hw.log" -f null -
- P1 (HW): ffmpeg -r 24000/1001 -i test.mkv -r 24000/1001 -i test_p1-hw.mov -lavfi psnr="stats_file=test_p1-hw.log" -f null -
PSNR results:
- P3 (Q4): PSNR y:57.830199 u:61.702542 v:64.312729 average:58.951441 min:56.685113 max:inf
- P1 (QX): PSNR y:57.672183 u:62.738864 v:65.896872 average:58.958489 min:53.148347 max:inf
- P2 (HW): PSNR y:62.149857 u:63.255604 v:66.544010 average:62.822763 min:58.255157 max:inf
- P1 (HW): PSNR y:57.895307 u:61.791684 v:65.122727 average:59.052011 min:55.453200 max:inf
Would love to hear your take on both these questions.
Thanks in advance!
Resolve-L3.xml
(2.8 MiB) Downloaded 627 times
CM_analyze-L3.xml
(2.12 MiB) Downloaded 585 times
#10986 Post by RESET_9999 » Mon May 26, 2025 5:50 pm
I dont think the difference is big enough to have a noticeable difference in playback but if I had to guess, I would say CM might be more accurate because other things can interfere in resolve.
FYI, I did new and better test file for L1 and it seems that the average_pq has no effect at all in cmv4.0, not even high values way above my TV ABL. DV dims the image only when L1 max_pq reaches your TV target.
In cmv2.9, a 150nits max/avg_pq dims the image even on my 2500nits G5, which doesn't make much sense since the TV can do 2500 peak / 400nits full field, and this is exactly why the generated L2 trims brightens the image so much in 2.9. see: https://docs.google.com/spreadsheets/d/ ... 1289366200
So I'm no longer watching 2.9 retail movies. CMv4.0 for everything!
As for the XML header primaries, unless you encode in DEE, it doesn't matter.
As for the ProRes profile, as long as the brightness and colors remain the same, I don't think it matters much.
PS: The CM warning msg are gone in the latest version. It also fixed my Windows 11 crashes.
coopzr
#10987 Post by coopzr » Tue May 27, 2025 4:49 am
RESET_9999 wrote: Mon May 26, 2025 5:50 pm FYI, I did new and better test file for L1
Is it these files last modified 8th May 2025?
RESET_9999 wrote: Mon May 26, 2025 5:50 pm So I'm no longer watching 2.9 retail movies. CMv4.0 for everything!
I've only just started avoiding cmv2.9 with a 4000 nits MDL due to the broken behaviour on my LG C4.
Are you saying there is more broken behaviour at other MDL's?
#10988 Post by RESET_9999 » Tue May 27, 2025 10:45 am
coopzr wrote: Tue May 27, 2025 4:49 am Is it these files last modified 8th May 2025?
yes
1000 mdl doesn't dim too early like 4000mdl but it is slightly crushed.
foxbat
#10989 Post by foxbat » Tue May 27, 2025 12:25 pm
I apologize if I have missed some developments, but, are we now able to convert retail CMv2.9 to CMv4.0? If so how involved is that process?
#10990 Post by RESET_9999 » Tue May 27, 2025 12:32 pm
foxbat wrote: Tue May 27, 2025 12:25 pm
You can restore cmv4.0 on a P7 rip with the metadata from web streaming. If no cmv4.0 source is available, then I will just generate it.
https://www.youtube.com/watch?v=RI_e-MPIPlw
bbeny123
#10991 Post by bbeny123 » Tue May 27, 2025 1:45 pm
RESET_9999 wrote: Tue May 27, 2025 12:32 pm You can restore cmv4.0 on a P7 rip with the metadata from web streaming. If no cmv4.0 source is available, then I will just generate it.
But wouldn’t generating CMv4.0 metadata mean losing the original manual L2 trims? In that case, wouldn’t it be better to just stick with CMv2.9 if those trims were carefully tuned?
#10992 Post by RESET_9999 » Tue May 27, 2025 2:14 pm
bbeny123 wrote: Tue May 27, 2025 1:45 pm But wouldn’t generating CMv4.0 metadata mean losing the original manual L2 trims? In that case, wouldn’t it be better to just stick with CMv2.9 if those trims were carefully tuned?
My 2500nits G5 rarely needs tone mapping, so this doesn't really affect me, and all the 1000nits MDL trims are already ignored anyway on this TV.
For 4000nits MDL RPU, even in movies that have a lot of modification in the cmv2.9 trims like Mad Max, DV still dims a lot of 200-500nits shots on my G5.
daffie
#10993 Post by daffie » Tue May 27, 2025 2:50 pm
RESET_9999 wrote: Tue May 27, 2025 2:14 pm
And for us people with G1/G2 for example?
LG OLED65G1RLA / Samsung HW-Q990D / Panasonic UB820 / Ugoos AM6B+ (CE with avdvplus Build)
#10994 Post by RESET_9999 » Tue May 27, 2025 3:18 pm
daffie wrote: Tue May 27, 2025 2:50 pm
I would generate cmv4.0 for movies made in the old/original cmv2.9 algo (the ones with no automatic trims, no cmv4.0 to 2.9 conversion).
For the cmv2.9 rpu with automatic L2 trims from the cmv4.0 workflow master, I guess it's fine(minus black crush).
PS: Dolby knows that cmv2.9 is not very good, see their QC recommendations:
https://www.youtube.com/watch?v=t7mlzQNSdOw&t=3718s
bbeny123
#10995 Post by bbeny123 » Tue May 27, 2025 3:32 pm
RESET_9999 wrote: Tue May 27, 2025 3:18 pm I would generate cmv4.0 for movies made in the old/original cmv2.9 algo (the ones with no automatic trims, no cmv4.0 to 2.9 conversion).
I ran some tests on my Sony A95L, and it seems tone mapping starts at:
  • avg_pq 600, MDL 1000, CM v2.9: 1150 nits
  • avg_pq 600, MDL 1000, CM v4.0: 1150 nits
  • avg_pq 600, MDL 4000, CM v2.9: 150 nits!
  • avg_pq 600, MDL 4000, CM v4.0: 1150 nits
How can one be sure that the old algorithm is being used?
Does having empty L2 trims guarantee the use of the legacy algorithm, or is there another way to confirm it?
