The Marvels (2023) BluRay won't rip
Everything related to Blu-ray 3D and 3D MKV files
RevAdler
Post by RevAdler »
"The Marvels" (2023)
I've attempted to rip 2 different discs on 4 different BD drives and always get a failure on the feature film movie on the disc.
Neither disc appeared damaged. Both Discs & a PC drive were cleaned.
Any suggestions?
Re: The Marvels (2023) BluRay won't rip
Generally speaking, MakeMKV gives error messages when it cannot rip a disk. It also generally creates files to use for resolving the issue. Are we allowed to know this, or are we to simply guess at why yours failed?
RevAdler
Post by RevAdler »
OK ... how about this?
MakeMKV_log.txt
(291.76 KiB) Downloaded 2720 times
Reading from the log, I see:
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00705.m2ts' at offset '14157938688'
002003:0000 Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '14157938688'
a LOT.
The offset is likely a problem area on the disk, which could be because of a smudge, scratch, or something making it give invalid data when read.
Another possibility is that the drive was spinning too fast for the power available, which can happen on USB-powered drives. In such cases, the offset will change with different runs.
RevAdler
Post by RevAdler »
Ok thanks...
(FWIW, this attempt was an internal drive)
Internal drives usually do not have power issues (one hopes!), so the offset should not move about. Smudge is more likely, so cleaning the disk should help. Remember to use a non-scratching cloth, and wipe radially (not around, but across) to minimize scratches.
