The Marvels (2023) BluRay won't rip
Everything related to Blu-ray 3D and 3D MKV files
RevAdler
Post by RevAdler » Mon May 26, 2025 1:27 am
"The Marvels" (2023)
I've attempted to rip 2 different discs on 4 different BD drives and always get a failure on the feature film movie on the disc.
Neither disc appeared damaged. Both Discs & a PC drive were cleaned.
Any suggestions?
Re: The Marvels (2023) BluRay won't rip
Post by Woodstock » Mon May 26, 2025 11:22 am
Generally speaking, MakeMKV gives error messages when it cannot rip a disk. It also generally creates files to use for resolving the issue. Are we allowed to know this, or are we to simply guess at why yours failed?
RevAdler
Post by RevAdler » Mon May 26, 2025 11:11 pm
OK ... how about this?
MakeMKV_log.txt
(291.76 KiB) Downloaded 2111 times
Post by Woodstock » Tue May 27, 2025 1:59 am
Reading from the log, I see:
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00705.m2ts' at offset '14157938688'
002003:0000 Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '14157938688'
a LOT.
The offset is likely a problem area on the disk, which could be because of a smudge, scratch, or something making it give invalid data when read.
Another possibility is that the drive was spinning too fast for the power available, which can happen on USB-powered drives. In such cases, the offset will change with different runs.
RevAdler
Post by RevAdler » Tue May 27, 2025 4:24 pm
Ok thanks...
(FWIW, this attempt was an internal drive)
Post by Woodstock » Tue May 27, 2025 6:23 pm
Internal drives usually do not have power issues (one hopes!), so the offset should not move about. Smudge is more likely, so cleaning the disk should help. Remember to use a non-scratching cloth, and wipe radially (not around, but across) to minimize scratches.
