Archgon MD-8107S-U3YC-UHD Hash Check Errors
davon
Post by davon »
Hey all, I am having troubles opening any blu-ray disc(Tried 6 different ones, 4 used, 2 new, and yes I have cleaned them and they read fine in a normal player) using a brand new Archgon MD-8107S-U3YC-UHD, but I keep getting a "BD+ code processed but no FUTs were obtained, errors may follow" pop uo and then "Hash check failed for x". Please let me know if its something simple or if I should return the drive and get something better. Here is my drive info in MakeMKV:
OS device name: E:
Product: BD-RE BU40N
Revision: 1.03
Serial number: ...
Highest AACS version: 60
Firmware version: 1.03
Errors: MakeMKV v1.18.1 win(x64-release) started
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/generic.svq
Saved BD+ dump file as C:\Users\rootb/.MakeMKV/dump_Deadpool_AB9701E710C1810E.tgz
Title #00131.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00250.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00356.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00370.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00371.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00251.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00378.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00379.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Hash check failed for file 02663.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02663.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02663.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02663.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02663.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02663.m2ts.
File 00391.mpls was added as title #0
Title #00372.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00374.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00376.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00373.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00375.mpls has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00377.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00380.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00382.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00384.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00386.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00381.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00383.mpls has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00385.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00387.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00392.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Hash check failed for file 02681.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02681.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02681.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02681.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02681.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02681.m2ts.
File 00394.mpls was added as title #1
Hash check failed for file 02682.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02682.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02682.m2ts at offset 583680, file is corrupt.
File 00396.mpls was added as title #2
Hash check failed for file 02684.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02684.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02684.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02684.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02684.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02684.m2ts.
File 00395.mpls was added as title #3
File 00397.mpls was added as title #4
Title #00388.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00389.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Hash check failed for file 02706.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02706.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02706.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02706.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02706.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02706.m2ts.
File 00393.mpls was added as title #5
Hash check failed for file 02707.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02707.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02707.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02707.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02707.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02707.m2ts.
File 00390.mpls was added as title #6
Title #00012.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Hash check failed for file 01741.m2ts at offset 190464, file is corrupt.
Hash check failed for file 01741.m2ts at offset 387072, file is corrupt.
Hash check failed for file 01741.m2ts at offset 583680, file is corrupt.
Hash check failed for file 01741.m2ts at offset 780288, file is corrupt.
Hash check failed for file 01741.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 01741.m2ts.
File 00020.mpls was added as title #7
Hash check failed for file 02577.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02577.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02577.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02577.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02577.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02577.m2ts.
File 00800.mpls was added as title #8
Title 00850.mpls is equal to title 00800.mpls and was skipped
Title #00328.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Hash check failed for file 02619.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02619.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02619.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02619.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02619.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02619.m2ts.
File 00301.mpls was added as title #9
Title #00302.mpls has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Hash check failed for file 02618.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02618.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02618.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02618.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02618.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02618.m2ts.
File 00303.mpls was added as title #10
File 00304.mpls was added as title #11
Hash check failed for file 02620.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02620.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02620.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02620.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02620.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02620.m2ts.
File 00305.mpls was added as title #12
Title #00306.mpls has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00307.mpls has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00308.mpls has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00309.mpls has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00310.mpls has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00311.mpls has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Hash check failed for file 02632.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02632.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02632.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02632.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02632.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02632.m2ts.
File 00313.mpls was added as title #13
File 00318.mpls was added as title #14
Hash check failed for file 02635.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02635.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02635.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02635.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02635.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02635.m2ts.
File 00320.mpls was added as title #15
Hash check failed for file 02634.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02634.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02634.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02634.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02634.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02634.m2ts.
File 00321.mpls was added as title #16
File 00322.mpls was added as title #17
Hash check failed for file 02641.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02641.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02641.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02641.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02641.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02641.m2ts.
File 00335.mpls was added as title #18
Hash check failed for file 02647.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02647.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02647.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02647.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02647.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02647.m2ts.
File 00335.mpls(2) was added as title #19
Hash check failed for file 02653.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02653.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02653.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02653.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02653.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02653.m2ts.
File 00335.mpls(4) was added as title #20
Title #00336.mpls has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00337.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00338.mpls has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Hash check failed for file 02640.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02640.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02640.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02640.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02640.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02640.m2ts.
File 00340.mpls was added as title #21
Title #00341.mpls has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00342.mpls has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00343.mpls has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00344.mpls has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Hash check failed for file 02648.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02648.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02648.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02648.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02648.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02648.m2ts.
File 00347.mpls was added as title #22
Title #00348.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00349.mpls has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00350.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00351.mpls has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00352.mpls has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00353.mpls has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00354.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00801.mpls is equal to title 00800.mpls and was skipped
Title 00851.mpls is equal to title 00800.mpls and was skipped
Title #00600.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01756.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00200.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02451.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01927.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02559.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02450.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02608.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00150.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Hash check failed for file 02636.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02636.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02636.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02636.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02636.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02636.m2ts.
File 02636.m2ts was added as title #23
Title #02657.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Hash check failed for file 02628.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02628.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02628.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02628.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02628.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02628.m2ts.
File 02628.m2ts was added as title #24
Hash check failed for file 02629.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02629.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02629.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02629.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02629.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02629.m2ts.
File 02629.m2ts was added as title #25
File 02640.m2ts was added as title #26
File 02641.m2ts was added as title #27
Title #02646.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 02647.m2ts was added as title #28
File 02648.m2ts was added as title #29
Hash check failed for file 02659.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02659.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02659.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02659.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02659.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02659.m2ts.
File 02659.m2ts was added as title #30
Title #02686.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02705.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Hash check failed for file 02713.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02713.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02713.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02713.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02713.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02713.m2ts.
File 02713.m2ts was added as title #31
Hash check failed for file 02710.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02710.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02710.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02710.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02710.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02710.m2ts.
File 02710.m2ts was added as title #32
Hash check failed for file 02714.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02714.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02714.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02714.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02714.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02714.m2ts.
File 02714.m2ts was added as title #33
Encountered 992 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
Re: Archgon MD-8107S-U3YC-UHD Hash Check Errors
Errors like that indicate the drive was unable to correctly read a spot on the disc. Often this is because the disc is dirty. But it could be the case that the optics on the drive are dirty and should be gently cleaned with isopropyl alcohol and a q-tip, twice, then gently dried.
Pioneers dont do this that's why they are recommend
But try cleaning your lasers with some alcohol
