ASUS SBW-06D2X-U
Hamiltonblue
Re: ASUS SBW-06D2X-U
Post by Hamiltonblue » Sat May 17, 2025 10:39 am
Running now
Thank You Billy!!!
maily.spamy
Post by maily.spamy » Sat May 17, 2025 9:04 pm
I have this drive:
OS device name: E:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.03
Serial number: ...
Firmware date: 2016-12-16
Drive platform: RS8510
Firmware version: 1.03/ID22
Can I update the new firmware from ASUS to enable M-Disc and stay it LibreDrive enabled?
revere
Post by revere » Sat May 24, 2025 3:39 pm
Coopervid wrote:
Sun Feb 16, 2025 6:09 pm
revere wrote:
Sun Feb 16, 2025 4:51 pm
Hi coopervid, can you please assist in getting Libredrive firmware for my drive?
Stasjon informasjon
Operativsystemets stasjons navn: D:
Produsent: ASUS
Produkt: SBC-06D2X-U
Revisjon: 1.10
Serienummer:
Firmware dato: 2017-04-18
Krypteringsflagg for databus: 1B
Drive platform: RS8591
Firmware version: 1.10/ID22
PM sent.
Hi Coopervid,
the firmware you provided was not accepted by the drive. Was the wrong firmware sent accidentally?
See error message and device information here:
Post by Coopervid » Sat May 24, 2025 4:23 pm
Your drive is not a BD writer but a BD combo and can‘t be flashed.
revere
Post by revere » Sun May 25, 2025 3:53 pm
Thanks for the update. You had identified this drive as one suppported earlier, but this seems to be wrong then. Seems like I have to look for a new drive to get the features I need.
GoesWithEverything
Post by GoesWithEverything » Sun May 25, 2025 11:03 pm
Hi there,
I also have this drive. I am hoping to enable LibreDrive for this writer. Is there anything I need to do to make this happen?
OS device name: E:
Manufacturer: ASUS
Revision: 1.10
Serial number: [Redacted, unless needed]
Firmware date: 2017-04-18
Firmware version: ID22
Post by Coopervid » Mon May 26, 2025 1:00 am
I was quite in a hurry since I'm on vacation and travelling. Firmware 8591 identifies it as a combo and I should have noticed that. Sorry!
Post by Coopervid » Mon May 26, 2025 1:01 am
Hi there,
OS device name: E:
Manufacturer: ASUS
Revision: 1.10
PM sent.
kaulvirus
Post by kaulvirus » Fri May 30, 2025 6:39 pm
I am in the same boat. Wondering if I could be helped as well?
OS device name: E:
Manufacturer: ASUS
Revision: A102
Serial number: MOAN
Firmware date: 2121-06-28 13:41
Bus encryption flags: 1F
ashahzadpk
Post by ashahzadpk » Sat May 31, 2025 5:30 am
OS device name: I:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
please help. thanks in advance
Still waiting for response Please help
Post by dcoke22 » Sat May 31, 2025 3:41 pm
OS device name: E:
Manufacturer: ASUS
Revision: A102
Serial number: MOAN
Your drive looks to be same as the one mentioned in this post: https://forum.makemkv.com/forum/viewtopic.php?p=173318#p173318
The drive platform is MT1959, which means the drive's internals are the same as other LG drives. As such, you can flash it yourself using the tools and instructions in the Ultimate UHD Drives Flashing Guide. As Billycar11 says in the referenced post, follow the instructions for the LG BU40N with encrypted firmware.
kaulvirus
Post by kaulvirus » Sat May 31, 2025 4:07 pm
OS device name: E:
Manufacturer: ASUS
Revision: A102
Serial number: MOAN
Thanks so much!
zShionz
Post by zShionz » Sun Jun 01, 2025 4:11 pm
Hi, I have this Blu-ray and I would like to make it compatible with UHD discs.
OS device name: H:
Manufacturer: ASUS
Revision: 1.10
Serial number:
thank you.
ashahzadpk
Post by ashahzadpk » Mon Jun 02, 2025 4:50 am
OS device name: I:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
Still waiting Please Help
Post by Coopervid » Mon Jun 02, 2025 6:14 am
OS device name: H:
Manufacturer: ASUS
Revision: 1.10
Serial number:
thank you.
PM sent.
