Hello ,
i have a request please;
since have flashed a LG Drive NS55 to supported firmware for UHD NS60 with the shared firmware here on the Forum;
it functioned for 1-2 Bluray but was noisy from the start after the new firmware was applied;
now it seems, the Drive is no longer recognizing any Bluray discs at all; DVD are still recognized;
i would like to attempt to restore the original Firmware, but unfortunately cannot find the saved file any longer;
if any of you can help, would be glad, maybe the drive could retain functionality of reading normal non-UHD Bluray and writing to Bluray with the original Firmware;
otherwise, would have to consider the Bluray functionality as lost on this drive;
Thank you
LG flashed to LibreDrive no longer recognize BluRay - Orig. Firmware lost
kapqa
kapqa
Re: LG flashed to LibreDrive no longer recognize BluRay - Orig. Firmware lost
please move post to section "Libre Drive" thank you.
changing fw will not cause a change rebooting the drive could
turn it off for 5 mins then power backup and see if it works if not clean the lasers
if it still does not work after that the Blu-ray laser died lg/asus rebrand drives have been extremely unreliable
kapqa
sorry , i have made a mistake, the drive in question is a CH12NS40;
will attempt to restore original firmware.
edit> attempting to flash original firmware not succesful, since ODD app says it has alreaadyu latest firmware applied.
maybe someone can share the original firmware, file to flash for windows thanks,
it should be like
N1.01_CH12NS40_171121_only_NOBJ.exe
for some reason, download does not function at the moment.
https://hitachi-lg.com/jp/support/firmw ... load/?v=20
it should be like
kapqa
hello , thanks , i have found the backup file , but SPI flash cannot read it since it is TAR file and SPI flash attempting to read/write bin file.
when i extract tar file, getting several file, maybe you can help restore the proper firmware.
kapqa
Hello ,\
i would kindly need help with downgrading the firmware if possible<
have now found the original firmware .exe from LG for the drive,
but it would not allow me to use it since the drive is not recognized as CH12NS40 but now as WH16NS60
found the download links here
https://www.lg.com/de/support/produkt-h ... QZRzVYVbBT
also have the original dump firmware saved as tar which seems even earlier firmare from 2017.
thank you very much.
kapqa
nevermind, could flash back with the help of this firmware package here CH12NS40 1.01 or 1.03 included<
but would still not read any Bluray<
would it make a difference if could use DOSFLASH as shown here
https://www.youtube.com/watch?v=eXgybNfHhcg
would like to restore 1.00 but donT know how since the dump is in .tar file and not .bin.
thanks.
thanks.
VA1DER
The dump you made was of an encrypted firmware, so the actual original firmware is not in the dump . tar. What's in that dump are drive settings. Your original firmware is lost.
I agree with others that suggest your blue laser failed.
Recommend getting genuine WH16NS40, NS55 or NS60. You can find most of these on eBay or Ali Express. There are even some promising looking Pioneers on Ali Express from 2018 that likely have compatible firmware (look at post in drives for sale subforum) though there is a little risk associated with those.
kapqa
Thanks, didnt know that;VA1DER wrote: Mon Jun 02, 2025 12:37 pm The dump you made was of an encrypted firmware, so the actual original firmware is not in the dump . tar. What's in that dump are drive settings. Your original firmware is lost.
how could i have averted the risk?^
the software has not averted me of the risk, unfortunately. maybe i just skipped the tutorial too fast.
the drive was just functioning so well previously, barely used; hardly the laser could have died without getting proper usage, but one never may know for sure with these technologyu.
thanks , for the tip, i was in market for a pioneer, but then found out that the retail price of 1''00 euro is actually for a "refurbished", so might aswell get on more LG drive; m
favorite would have been ASUS drive, but people seem to write they are even more loud and unrelialble at reading bluray disc , even just 1080p for playback.
VA1DER
Knowing the drive and firmware you were putting on it is key.
There is no way, unless you happen to geta drive with unencrypted firmware (more later), to back up the original firmware. So check. Double check. Triple check before that first flash.
The CH12NS40 you have isn't the BH16NS55 you thought it was. It's not outside the realm of possibility that the blue lasers are different enough that the firmware you tried to put on it operated it outside its specs and burned it out. Or (more likely) burned out transistors in the controller chip.kapqa wrote: Tue Jun 03, 2025 1:42 pmthe drive was just functioning so well previously, barely used; hardly the laser could have died without getting proper usage, but one never may know for sure with these technologyu.
And it won't often warn you. The software is designed to do things the manufacturer didn't intend, to operate outside of "rules", and to allow one to experiment. It assumes you know what you want to do is correct. It might seem that people here casually flash all the time, but it's inherently risky and unless you really understand the electronics in each model, people only put well known firmware on well known compatible drives.kapqa wrote: Tue Jun 03, 2025 1:42 pmthe software has not averted me of the risk, unfortunately. maybe i just skipped the tutorial too fast.
One option is an actual WH16NS60: https://www.ebay.ca/p/7025081230kapqa wrote: Tue Jun 03, 2025 1:42 pmthanks , for the tip, i was in market for a pioneer, but then found out that the retail price of 1''00 euro is actually for a "refurbished", so might aswell get on more LG drive; m
I ordered one from that listing and have it on my desk. It came with an UNencrypted v1.0 firmware that is MakeMKV ready out of the box. Meaning you can back up the original firmware (backs up into a .bin), and reflash it with MK later ones, or even scanning firmware like WH16NS58. But as it's an UHD official drive with Libredrive support, you don't have to flash it at all.
kapqa
Thank you for the support<One option is an actual WH16NS60: https://www.ebay.ca/p/7025081230
what do you mean by "scanning firmware"?
dont know if it would be easily import to Europe/
for such price you can now get also like Pioneer Drives new on Ebay, but i understand that those drives are not yet ready for UHD Firmware, that should come later.
would not mind, most important thing is reliability and ability to read/burn different media without hiccups or too much noise.
what do you think of such an offer like this
https://www.ebay.it/itm/156810626913?_t ... p_homepage
VA1DER
It's a good drive. Essentially the same hardware as a BDR-S12EBK. However it doesn't have UHD firmware. It should work with MakeMKD for non-UHD discs. If the date on the photo is accurate, then it should be cross-flashable. Just know that almost everyone on this forum who have cross-flash firmware for it will want to soak you money for it. I don't know if the announcement that all Pioneer drives will be LibreDrive supported extends to ripping UHD off of drives without a UHD firmware, but I suspect not.kapqa wrote: Thu Jun 05, 2025 10:14 am what do you think of such an offer like this
If you don't want UHD, or are willing to bribe someone here that has a cross-flash firmware to send it to you, then the drive should be good.
[EDIT]
Sorry, forgot to address that. Disc scanning is where a drive with diagnostic commands enabled (like an LG WH16NS58 which is intended for people who do bulk disc duplication burning) is used to scan a disc for its burn quality. You may have seen disc scans like this:
It shows how much a drive's error correction is being used to make the disc readable - there isn't an error free optical disc on the planet, and without diagnostic software you can't tell if a burn is really good, or marginal. The error correction masks a marginal burn because you can't tell how close to the error correction's edges a disc is at. If you do a lot of burns, or are into hobbyist media scanning, it can use useful/fun. It's somewhat handy for UHD ripping because it can help you see if a rip problem is due to a flaw on the disc or not. There used to be a bigger hobbyist scene for this than there is now. I like to have the capability, but not everyone is interested.
kapqa
thank you for clarifying;
i have ripped some UHD Bluray now with help of Makemkv software , and those have functioned well for playback;
but i have made copies of DVD in the past, and after some years with nearly no playback, they already fail to be playbacked properly, so such a scanning software/firmware seems a handy thing;
would be a pity if also Bluray copies would stop being recognized after some years of "no-use";
but it seems most Blruay media are all M-Disc? and for DVD, M-Disc is something special only?
for now , have one drive left that is NS55 flashed to NS60 with the suggested "all-in-one"Firmware here from the forum, that could serve as the UHD-ripping drive, so i would not mind buying a non-UHD Pioneer drive;
the WH16NS60 link you shared amounts after shipping and taxes to around 170 euro, which i consider excessive at the moment.
could you think of another Pioneer drive that could already be UHD-enabled? but the ones have seen on a list are all 200+ euro if i am not mistaken;
is this scanning software thing exclusive to LG drives? was thinking also of ASUS drive since those are easily available via Amazon or similar for around 85 eruro.
VA1DER
Wow. Shipping must be crazy. I got it for about $100CAD, shipped.kapqa wrote: Fri Jun 06, 2025 10:12 am the WH16NS60 link you shared amounts after shipping and taxes to around 170 euro, which i consider excessive at the moment.
That's a reasonable drive. As far as I can tell, an NS55 is basically identical to an NS60 with the exception of some silicon for actual UHD-official playing, which is impossible nowadays anyway since there are no more PC official players.
If you are looking at half-height drives (which are faster and more stable), then you need a: BDR-S11?**, BDR-X11?** or later (so S12, S13, X12, X13). Where the ? is the region (e=europe, u=us, c=china, j=japan) and ** is the submodel ("BK" = regular, and "-X" = the Cadillac). The "S" models are internals you will need an enclosure for or a desktop computer to put it in. The X models are externals.kapqa wrote: Fri Jun 06, 2025 10:12 am could you think of another Pioneer drive that could already be UHD-enabled?
The catch is they have to have a firmware BEFORE December 2022. OR, if you get a later one, then you need to wait for the promised new LibreDrive method to use the new ones is available.
If you are looking at slimline, I'm less familiar with those models. You can find info around here if you search. I have an older Verbatim branded drive that came with an OEM Pioneer BDR-UD03 in it that I cross-flashed to a BDR-UD04. It was my first UHD drive. You can still find those Verbatims around, but the new ones aren't Pioneers any more - they are now an LG slimline. Some of the older ones have BDR-UD03's, which you will need to get a firmware update for. Some of them have BDR-UD04's in them, which are good to go out of the box. This would be the very basic, entry-level Pioneer. Good news is that it's portable. Bad news is that it's a slimline, which you have to be very careful with lest you scratch discs.
Asus drives are made by LG. I don't know of any Asus drives with diagnostic firmware in them. The only UHD drive I know of with scanning diagnostic firmware is the LG WH16NS58DUP. Some Asus drives can be cross-flashed with LG firmware, but there are pitfalls to this and I don't know the compatibility matrix - search around the forum, there is info on that here. Scanning-capable drives are rarer nowadays. But the NS55 you mentioned earlier can be flashed with the NS58 firmware.kapqa wrote: Fri Jun 06, 2025 10:12 amis this scanning software thing exclusive to LG drives? was thinking also of ASUS drive since those are easily available via Amazon or similar for around 85 eruro.
All 5,25" drives with a M1959 chip can be flashed to do quality checks when flashed to WH16NS58 V1.5 from the MK pack. It will also rip UHDs but the support of media is quite restricted for burning. But everybody should stop burning discs as their quality is getting worse. You should look into solutions that work from HDD backup. Cheaper and safer than discs.
