Pioneer BDR-UD03 UHD possibility
mali40
Re: Pioneer BDR-UD03 UHD possibility
Post by mali40 » Fri May 23, 2025 10:44 am
mali40 wrote: Thu May 22, 2025 10:24 am Hello,
I read that you can flash it to read UHD discs?
How do I do that?
I have a verbatim 43889.
Can you help me?
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: xxxxxxxxxxx
Firmware-Datum: 2020-06-15
Highest AACS version: 81
Drive platform: RS8511
Firmware version: 1.14
Keine Disk eingelegt
DeafBlindNoob
Post by DeafBlindNoob » Fri May 23, 2025 10:54 am
Hi, I'm in the same boat, a firmware pm would be greatly appreciated :)
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: DDDL524155WL
Firmware date: 2020-06-15
Highest AACS version: 19
Post by Coopervid » Sat May 24, 2025 4:32 am
DeafBlindNoob wrote: Fri May 23, 2025 10:54 am Hi, I'm in the same boat, a firmware pm would be greatly appreciated :)
OS device name: F:
Revision: 1.14
PM sent.
FireDesire
Post by FireDesire » Sat May 24, 2025 3:42 pm
Hi!
I have a BDR-US03 anyone can help? I want it to rip UHD, is it possible?
Thanks.
OS device name: F:
Revision: 1.03
Serial number: PG*********
Firmware date: 2015-05-14
Drive platform: RS8510
Firmware version: 1.03/ID19
plattfot
Post by plattfot » Sat May 24, 2025 4:53 pm
I just started collecting UHD but sadly my drive BDR-UD03 drive cannot read them. Any help would be appreciated.
OS device name: /dev/sr0
Revision: 1.11
Serial number: SE**********
Firmware date: 2018-11-28
Firmware version: 1.11
Post by Coopervid » Sun May 25, 2025 12:13 am
FireDesire wrote: Sat May 24, 2025 3:42 pm Hi!
Thanks.
OS device name: F:
Revision: 1.03
PM sent.
dietburrito
Post by dietburrito » Wed May 28, 2025 6:43 am
dietburrito wrote: Wed Apr 30, 2025 6:03 am Hi, Can I please have my drive flashed too
OS device name: H:
Revision: 1.11
Serial number: <redacted>
Highest AACS version: 71
Thank you
Post by Coopervid » Thu May 29, 2025 2:37 am
plattfot wrote: Sat May 24, 2025 4:53 pm Hi,
Revision: 1.11
PM sent.
Post by Coopervid » Thu May 29, 2025 2:38 am
dietburrito wrote: Wed May 28, 2025 6:43 am
OS device name: H:
Revision: 1.11
Thank you
PM sent.
zaptester
Post by zaptester » Wed Jun 04, 2025 8:07 pm
MakeMKV is saying following for my Verbatim USB drive:
is it possible to enable UHD?
OS device name: E:
Revision: 1.14
Serial number: xxxxxxxxxxxxxx
Post by Coopervid » Thu Jun 05, 2025 5:09 am
zaptester wrote: Wed Jun 04, 2025 8:07 pm MakeMKV is saying following for my Verbatim USB drive:
OS device name: E:
Revision: 1.14
PM sent.
zaptester
Post by zaptester » Thu Jun 05, 2025 10:43 am
thx, but MakeMKV does not show any change in firmware. It is true that Disc information is now showed, but not playable.
(I tried 3). It does copy content to disk.
BTW playerfab still says it does not recognize drive.
see printscreen attachment
Post by Billycar11 » Thu Jun 05, 2025 1:50 pm
zaptester wrote: Thu Jun 05, 2025 10:43 am thx, but MakeMKV does not show any change in firmware. It is true that Disc information is now showed, but not playable.
You have other issues the fw did change it's now a ud04.
And sees UHD
Your issue is your ISP blocking key downloads
kdgsv
Post by kdgsv » Fri Jun 06, 2025 8:41 am
Some help needed for this drive.
Does not detect UHD disk.
Thx in advanced
OS-Gerätename: /dev/sr0
Produzent: PIONEER
Revision: 1.14
Serienummer:
Highest AACS version: 57
zaptester
Post by zaptester » Fri Jun 06, 2025 5:17 pm
Oh, you are right, that string has changed.
I do not think it is about blocked download, I do not see any indication of it, more like those keys do not exist for my UHD?
But that would be my problem, you have solved the first part for me, thx very much.
Billycar11 wrote: Thu Jun 05, 2025 1:50 pm You have other issues the fw did change it's now a ud04.
And sees UHD
