ASUS BW-16D1X-U - Flashable?
Re: ASUS BW-16D1X-U - Flashable?
Post by Coopervid » Sat May 24, 2025 4:35 am
djyip13 wrote: Fri May 23, 2025 11:13 pm Hello from Miami!
I am completely new to this from a firmware flash perspective and could use some major help. Here is the information as reported by MakeMKV:
Current profile: DVD-ROM
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number: -------------
Firmware date: 2017-12-21
Highest AACS version: 76
Drive platform: RS8601
Firmware version: E111/ID76
Any help would be greatly appreciated. Thanks in advance.
PM sent.
Mutato
Post by Mutato » Sun Jun 01, 2025 12:42 pm
Hi, I bought an ASUS BW-16D1H-U PRO, how can I flash it to UHD drive?
Previously I flashed my LG BH16NS40 (NS50) using cmd commands but this drive has problems with reading 3 layer discs. Sometimes it reads them sometimes throws errors "L-EC UNCORRECTABLE ERROR" and sometimes it doesn't work at all (making a strange sound).
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Firmware date: 2020-07-21
Highest AACS version: 78
Drive platform: RS8F00
Firmware version: E116/ID71
Thanks for your help
niddrym
Post by niddrym » Sun Aug 10, 2025 12:56 am
I have the following drive, is it flashable via another method since its not an MT1959?
OS device name:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number: ...
Highest AACS version: 77
Post by Billycar11 » Sun Aug 10, 2025 3:40 am
niddrym wrote: Sun Aug 10, 2025 12:56 am Hi,
OS device name:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number: ...
Mutato wrote: Sun Jun 01, 2025 12:42 pm Hi, I bought an ASUS BW-16D1H-U PRO, how can I flash it to UHD drive?
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
yes just email me that info see below for email i have an auto flasher for you
Misty
Post by Misty » Fri Sep 12, 2025 5:26 pm
First time poster,
I had no problem finding information how to flash my Verbatim branded LG BU40N drive.That now reads UHD disks.
But finding the same information for my ASUS branded drive to read UHD disks have been a challenge.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Highest AACS version: 61
dracoola666
Post by dracoola666 » Sat Sep 13, 2025 8:35 pm
how can i flash a firmware for uhd support?
Aktuelles Profil: BD-ROM
Produzent: ASUS
Produkt: BW-16D1X-U
Revision: E113
Serienummer: DEDL115084WL
Firmware-Datum: 2020-07-21
Highest AACS version: 82
Firmware version: ID76
thx in advance
Cheesenugget1
Post by Cheesenugget1 » Sat Sep 13, 2025 8:42 pm
I also need help mine is the E113 version of the asus disc drive. Can anybody help?
Post by Billycar11 » Sun Sep 14, 2025 11:37 am
Cheesenugget1 wrote: Sat Sep 13, 2025 8:42 pm I also need help mine is the E113 version of the asus disc drive. Can anybody help?
dracoola666 wrote: Sat Sep 13, 2025 8:35 pm Hi,
Produzent: ASUS
Produkt: BW-16D1X-U
Revision: E113
thx in advance
Sure email me that drive info section see below for email
jmwilt21
Post by jmwilt21 » Sun Sep 14, 2025 11:58 pm
I have the same drive as mentioned above. Here is the drive information:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Is mine also flashable and can you help with that?
Post by Coopervid » Mon Sep 15, 2025 9:05 am
jmwilt21 wrote: Sun Sep 14, 2025 11:58 pm Hello,
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
PM sent.
oap1ikwydlsh2o
Post by oap1ikwydlsh2o » Mon Sep 15, 2025 8:47 pm
i have this drive is it too old to flash
OS DEVICE NAME : E
manufacturer :asus
product : BW -16D1X-U
REVISION :104
SERIAL NO
FIRMWARE DATE: 2119-01-04
BUS ENCRIPTION FLAGS :1F
HIGHEST AACS VERSION :82
LIBRE DRIVE INFO
STATUS :POSSIBLE (WITH PATCH)
DRIVE PLATFORM :MT1959
HARDWARE SUPPORT :YES
FIRMWARE SUPPORT :NO
FIRMWARE TYPE :ORIGINAL (PATCHED VERSION ONLY)
FIRMWARE VERSION : 0.A104W
Post by Coopervid » Mon Sep 15, 2025 9:04 pm
oap1ikwydlsh2o wrote: Mon Sep 15, 2025 8:47 pm i have this drive is it too old to flash
OS DEVICE NAME : E
manufacturer :asus
REVISION :104
SERIAL NO
LIBRE DRIVE INFO
No. You need to follow this.
viewtopic.php?f=16&t=19634
oap1ikwydlsh2o
Post by oap1ikwydlsh2o » Mon Sep 15, 2025 9:22 pm
i dont see my drive listed here , does the other asus drive listed work
Willie
Post by Willie » Fri Sep 19, 2025 9:07 pm
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Joining the fray!
Would like to know is this is flashable. Thanks!
(Insane that you have to do this when there's a Swedish law that says I am within my rights to copy any material I own)
Post by Billycar11 » Sat Sep 20, 2025 1:46 am
Willie wrote: Fri Sep 19, 2025 9:07 pm Drive Information
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Joining the fray!
Sure just send that info to the email below
