Kingdom of Heaven 4K Won't Load TGZ attached
reduser28
#1 Post by reduser28 » Fri May 23, 2025 7:44 pm
I'm thinking I might be one of the first in the world to get their hands on it and try it in MakeMKV so it's obviously not opening. Here's the dump file. I also emailed it.
keydb_helper
Re: Kingdom of Heaven 4K Won't Load TGZ attached
#2 Post by keydb_helper » Sat May 24, 2025 1:40 am
reduser28 wrote: Fri May 23, 2025 7:44 pm I'm thinking I might be one of the first in the world to get their hands on it and try it in MakeMKV so it's obviously not opening. Here's the dump file. I also emailed it.
Thanks for taking the time to provide your disc dump. The 3696 variant of Kingdom of Heaven has been supported by the public keydb since early yesterday.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
KeyDB Download
