mali40 wrote: Thu May 22, 2025 10:24 am Hello,
I read that you can flash it to read UHD discs?
How do I do that?
I have a verbatim 43889.
Can you help me?
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: xxxxxxxxxxx
Firmware-Datum: 2020-06-15
Highest AACS version: 81
Drive platform: RS8511
Firmware version: 1.14
Keine Disk eingelegt
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
DeafBlindNoob
Hi, I'm in the same boat, a firmware pm would be greatly appreciated
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: DDDL524155WL
Firmware date: 2020-06-15
Highest AACS version: 19
OS device name: F:
Revision: 1.14
PM sent.DeafBlindNoob wrote: Fri May 23, 2025 10:54 am Hi, I'm in the same boat, a firmware pm would be greatly appreciated
OS device name: F:
Revision: 1.14
FireDesire
Hi!
I have a BDR-US03 anyone can help? I want it to rip UHD, is it possible?
Thanks.
Thanks.
OS device name: F:
Revision: 1.03
Serial number: PG*********
Firmware date: 2015-05-14
Drive platform: RS8510
Firmware version: 1.03/ID19
I just started collecting UHD but sadly my drive BDR-UD03 drive cannot read them. Any help would be appreciated.
OS device name: /dev/sr0
Revision: 1.11
Serial number: SE**********
Firmware date: 2018-11-28
Firmware version: 1.11
PM sent.FireDesire wrote: Sat May 24, 2025 3:42 pm Hi!
Thanks.
OS device name: F:
Revision: 1.03
dietburrito
dietburrito wrote: Wed Apr 30, 2025 6:03 am Hi, Can I please have my drive flashed too
OS device name: H:
Revision: 1.11
Serial number: <redacted>
Highest AACS version: 71
Thank you
PM sent.plattfot wrote: Sat May 24, 2025 4:53 pm Hi,
Drive Information OS device name: /dev/sr0 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.11 Serial number: SE********** Firmware date: 2018-11-28 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.11 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
PM sent.dietburrito wrote: Wed May 28, 2025 6:43 amdietburrito wrote: Wed Apr 30, 2025 6:03 am Hi, Can I please have my drive flashed too
OS device name: H:
Revision: 1.11
Thank you
MakeMKV is saying following for my Verbatim USB drive:
is it possible to enable UHD?
OS device name: E:
Revision: 1.14
Serial number: xxxxxxxxxxxxxx
OS device name: E:
Revision: 1.14
PM sent.zaptester wrote: Wed Jun 04, 2025 8:07 pm MakeMKV is saying following for my Verbatim USB drive:
OS device name: E:
Revision: 1.14
thx, but MakeMKV does not show any change in firmware. It is true that Disc information is now showed, but not playable.
(I tried 3). It does copy content to disk.
BTW playerfab still says it does not recognize drive.
see printscreen attachment
- printscreen.jpg (145.54 KiB) Viewed 8160 times
You have other issues the fw did change it's now a ud04.zaptester wrote: Thu Jun 05, 2025 10:43 am thx, but MakeMKV does not show any change in firmware. It is true that Disc information is now showed, but not playable.
And sees UHD
Your issue is your ISP blocking key downloads
Some help needed for this drive.
Does not detect UHD disk.
Thx in advanced
OS-Gerätename: /dev/sr0
Produzent: PIONEER
Revision: 1.14
Serienummer:
Highest AACS version: 57
Thx in advanced
Produzent: PIONEER
Revision: 1.14
Serienummer:
Oh, you are right, that string has changed.
I do not think it is about blocked download, I do not see any indication of it, more like those keys do not exist for my UHD?
But that would be my problem, you have solved the first part for me, thx very much.
Billycar11 wrote: Thu Jun 05, 2025 1:50 pm You have other issues the fw did change it's now a ud04.
And sees UHD
