Issues with 4K Discs
dj248
#1 Post by dj248 » Tue May 20, 2025 12:41 am
Hi everyone!
I am facing some issues with ripping some 4K UHD discs onto my computer.
So far, I am able to drag and drop the contents of the discs onto my Desktop, but when I open them and process them in MakeMKV, they fail each time.
Overall, most movies work as intended, but a select few do not including Lilo & Stitch, Breakdown, Aladdin, and Zootopia.
Two different 4K UHD discs for Zootopia receive the same problem.
Also the first 4K player was a XRTFORE External 4k Blu Ray Drive which was not working.
I purchased a second 4K player which is the archgon Premium Aluminum External USB 3.0 UHD 4K Blu-Ray Writer Super Drive for PC and Mac and the same results take place.
I have also used soap and a microfiber cloth for cleaning purposes and no difference was made, so I am hesitant to believe that these are with the discs themselves.
Do you happen to have any guidance on this case?
The appropriate errors have been provided below for Lilo & Stitch.
If there is anything else that can be provided, please let me know.
Please keep me posted.
Thank you so much!
Lilo & Stitch Logs.txt
(121.92 KiB) Downloaded 532 times
Re: Issues with 4K Discs
#2 Post by MartyMcNuts » Tue May 20, 2025 1:29 am
dj248 wrote: Tue May 20, 2025 12:41 am Hi everyone!
Thank you so much!
You cannot drag & drop the disc content. It doesn't work that way.
Start by posting your MakeMKV drive info & libredrive info sections.
dj248
#3 Post by dj248 » Tue May 20, 2025 10:16 pm
Sure, thanks for the explanation. Here is this information below.
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: MO3O3UC0557
Firmware date: 2120-05-07 09:35
Highest AACS version: 78
Firmware version: 1.02
#4 Post by MartyMcNuts » Wed May 21, 2025 6:03 am
dj248 wrote: Tue May 20, 2025 10:16 pm Sure, thanks for the explanation. Here is this information below.
Revision: 1.02
Ok, so why are you trying to drag and drop the disc content? Why not just rip the disc with MakeMKV? If you click the folder button, you can backup the entire disc to a decrypted folder. Otherwise, click the big drive icon button to create a MKV file of the movie.
dj248
#5 Post by dj248 » Wed May 21, 2025 5:57 pm
Sorry if I didn't make it clearer earlier, it will not even rip via MakeMKV. I have attempted it multiple times.
#6 Post by MartyMcNuts » Thu May 22, 2025 3:06 am
dj248 wrote: Wed May 21, 2025 5:57 pm Sorry if I didn't make it clearer earlier, it will not even rip via MakeMKV. I have attempted it multiple times.
Clean the disc.
Replace the disc.
Clean the lasers.
Replace the drive.
dj248
#7 Post by dj248 » Thu May 22, 2025 3:39 am
This is my second drive now, not the first. As I mentioned in my original post, I received a replacement disc for one of the movies, Zootopia, and received the same result on both drives. I thought about the laser too, but it is happening with a brand new drive I just received two weeks ago. In the meantime, I will generate log results for the other failing movies. Were the logs I provided helpful above?
dj248
#8 Post by dj248 » Thu May 22, 2025 1:10 pm
Aladdin Logs have been posted.
Aladdin Logs.txt
(37.21 KiB) Downloaded 201 times
dj248
#9 Post by dj248 » Thu May 22, 2025 6:56 pm
ZooTopia Logs
ZooTopia Logs 1.txt
(78.84 KiB) Downloaded 208 times
dj248
#10 Post by dj248 » Fri May 23, 2025 12:11 am
Breakdown
Breakdown Logs.txt
(53.55 KiB) Downloaded 200 times
#11 Post by MartyMcNuts » Fri May 23, 2025 12:24 am
dj248 wrote: Thu May 22, 2025 3:39 am This is my second drive now, not the first. As I mentioned in my original post, I received a replacement disc for one of the movies, Zootopia, and received the same result on both drives. I thought about the laser too, but it is happening with a brand new drive I just received two weeks ago. In the meantime, I will generate log results for the other failing movies. Were the logs I provided helpful above?
You have multiple issues there...
1. You should probably use a faster drive for the output.
2. Your drive is having trouble reading all of those discs. Either the drive/laser/discs are the problem. Ensure you are using high powered USB-A ports or USB-C port direct from the motherboard or use a self powered USB hub (30w+).
In order:
Clean the discs with soapy water and a microfiber cloth. Dry with a microfiber cloth.
Clean the drive's lasers.
Replace the discs.
Replace the drive. Pioneer's are recommended if you can get one! They are far superior (like 1000% better) in every way compared to LG/ASUS.
Try some of the discs that have worked previously. If they still work, then the drive likely isn't the issue, the discs are.
dj248
#12 Post by dj248 » Mon May 26, 2025 2:36 am
Thank you for your suggestions and I will be purchasing a new copy of Lilo and Stitch for testing purposes.
