LibreDrive for Pioneer drives
Not yet, the firmware date is to new. No downgrade possible if newer than November 2022.
In the future it might be possible, have a look there ----> viewtopic.php?f=16&t=37848
It works! Thank you.Coopervid wrote: Thu May 22, 2025 4:54 amPM sent.PenPen wrote: Wed May 21, 2025 8:56 pm Hello, since I haven't received any feedback following my message, did I forget to mention some necessary information? Thank you in advance.
PenPen wrote: Fri May 09, 2025 2:42 pm Hello, can I make my BDR-XD07 play UHD blu-rays ? Thx
Drive Information OS device name: D: Manufacturer: PIONEER Product: BD-RW BDR-XD07 Revision: 1.03 Serial number: ... Firmware date: 2020-08-20 Bus encryption flags: 13 LibreDrive Information Status: Enabled Drive platform: RS8D30 Firmware name: PIONEER BDR-BDS7 Firmware type: Original (unpatched) Firmware version: 1.03 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
pantslessfrog
I have a BDR-XD05S as well. Tried following steps in other threads but it looks like I'm missing something key in order to read UHD discs. Any help would be appreciated.
OS device name: /dev/sr0
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: ------------
Firmware date: 2017-06-22
Highest AACS version: 65
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
PM sent.pantslessfrog wrote: Sat May 24, 2025 5:35 pm I have a BDR-XD05S as well. Tried following steps in other threads but it looks like I'm missing something key in order to read UHD discs. Any help would be appreciated.
Drive Information OS device name: /dev/sr0 Manufacturer: PIONEER Product: BD-RW BDR-XD05 Revision: 3.10 Serial number: ------------ Firmware date: 2017-06-22 Bus encryption flags: 1B Highest AACS version: 65 LibreDrive Information Status: Enabled Drive platform: RS8232 Firmware name: PIONEER BDR-XD05 Firmware type: Original (unpatched) Firmware version: 3.10/ID34 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Hi, I'm a BDR-XD05 user. If someone can send me a link to the appropriate firmware, I would appreciate it.
Revision: 1.20
Serial number: ,,,
Firmware date: 2013-11-15
Drive platform: RS8231
Firmware version: 1.20
Revision: 1.20
Serial number: ,,,
PM sent.darkstar1 wrote: Sun May 25, 2025 9:55 pm Hi, I'm a BDR-XD05 user. If someone can send me a link to the appropriate firmware, I would appreciate it.
Revision: 1.20
Serial number: ,,,
Hello, here is my drive.
- Screenshot 2025-05-28 221926.png (68.94 KiB) Viewed 16382 times
You need to wait until Mike can flash encrypted firmware. Be patient....
PhallicBaldwin
This is my drive:
OS device name: H:
Revision: 1.03
Serial number:
Am I good? Can I flash it?
OS device name: H:
Revision: 1.03
Serial number:
PM sent.PhallicBaldwin wrote: Thu May 29, 2025 7:02 pm This is my drive:
OS device name: H:
Revision: 1.03
Serial number:
Hello, if possible iwould also flash my drive.
wbr Alex
Laufwerksinformation
OS-Gerätename: G:
Produzent: PIONEER
Produkt: BD-RW BDR-XD05
Revision: 3.10
Serienummer:
Firmware-Datum: 2017-06-22
Highest AACS version: 72
wbr Alex
OS-Gerätename: G:
Produzent: PIONEER
Revision: 3.10
Serienummer:
DimensionFX
can I have a firmware too...
OS device name: F:
Product: BD-RW BDR-S09
Revision: 1.20
Serial number: ...
Firmware date: 2014-04-08
Drive platform: RS8600
Firmware version: 1.20/ID43
thank you
OS device name: F:
Revision: 1.20
Serial number: ...
thank you
PM sent.jasch wrote: Fri May 30, 2025 12:51 pm Hello, if possible iwould also flash my drive.
wbr Alex
OS-Gerätename: G:
Produzent: PIONEER
Revision: 3.10
Serienummer:
PM sent.DimensionFX wrote: Fri May 30, 2025 3:37 pm Hello,
OS device name: F:
Revision: 1.20
Serial number: ...
thank you
Packers948
Please let me know if this Pioneer – BDR-211UBK would be able to flash for UHD enable. Thank you so much for your help.
MakeMkv information as below.
OS device name: G:
Product: BD-RW BDR-211M
Revision: 1.02
Serial number: NA
Firmware date: 2017-02-23
Highest AACS version: 81
Drive platform: RS8800
Firmware name: PIONEER BDR-211
Firmware version: 1.02/ID60
OS device name: G:
Revision: 1.02
Serial number: NA
