PM sent.
Thanks man, this worked 100%. Is it possible to do something similar with this drive?
- Captura de tela 2025-05-22 005947.png (11.22 KiB) Viewed 52267 times
Hey, just passing by to thank you and everyone on this site, especially: Pat LaVarre, >NIL:, Agent Smith, Liggy, Mike Chen, ala42, czary2mary, jadburner, cvs, alexx12345, seku, Leman39, wujooj, jurireal, alphaville0527, SnowFox, Kirby, haysey70, Majestic12, elflorek, floppydumper, redwine, cryptojoe3737, TeddyRaspin, Billycar11, asmcom, Coopervid (thanks again), payalnik23, and aliter404.
Later, after reading the pinned post, I discovered that this drive was too old to be flashed, but with my third drive (WH14NS40), I managed to flash it to ---> WH16NS60. Thanks again, everyone. You’re awesome!
Just one question: I noticed that there are 3 different programs to flash the drives (BDRFlash, makemkvcon, and SDFGUI). All three worked correctly, but I just want to know if there are any differences between them. Thanks again, folks!
There is BDRFlash for Pioneer drives. Makekmvcon and the GUI for it written by Marty is SDFTool which uses Makemkvcon for LG / ASUS drives.edmsms wrote: Tue Jun 10, 2025 9:49 amHey, just passing by to thank you and everyone on this site, especially: Pat LaVarre, >NIL:, Agent Smith, Liggy, Mike Chen, ala42, czary2mary, jadburner, cvs, alexx12345, seku, Leman39, wujooj, jurireal, alphaville0527, SnowFox, Kirby, haysey70, Majestic12, elflorek, floppydumper, redwine, cryptojoe3737, TeddyRaspin, Billycar11, asmcom, Coopervid (thanks again), payalnik23, and aliter404.
Just one question: I noticed that there are 3 different programs to flash the drives (BDRFlash, makemkvcon, and SDFGUI). All three worked correctly, but I just want to know if there are any differences between them. Thanks again, folks!![]()
draughthorse
hi, i was wondering if my ASUS SBW-06D5H-U is flashable?
- SBW-06D5H-U.png (30.63 KiB) Viewed 50776 times
Yes. Use SDFTool and flash to BU40N.draughthorse wrote: Fri Jun 13, 2025 7:50 pm hi, i was wondering if my ASUS SBW-06D5H-U is flashable?
draughthorse
are you sure... im reading the uhd drive flashing guide and it tells me specifically not to crossflash between asus and lg because it will brick my drive. is there something im missing?Coopervid wrote: Sun Jun 22, 2025 2:11 pmYes. Use SDFTool and flash to BU40N.draughthorse wrote: Fri Jun 13, 2025 7:50 pm hi, i was wondering if my ASUS SBW-06D5H-U is flashable?
Yes. It's a slim drive. The warning is meant not to flash firmware of full size drives to slim drives and vice versadraughthorse wrote: Sun Jun 22, 2025 9:55 pmare you sure... im reading the uhd drive flashing guide and it tells me specifically not to crossflash between asus and lg because it will brick my drive. is there something im missing?Coopervid wrote: Sun Jun 22, 2025 2:11 pmYes. Use SDFTool and flash to BU40N.draughthorse wrote: Fri Jun 13, 2025 7:50 pm hi, i was wondering if my ASUS SBW-06D5H-U is flashable?
Hi! I've also the same model, I'd like to know if mine can be flashed:
sure email me that drive info belowsid87 wrote: Thu Jun 26, 2025 9:27 pm Hi! I've also the same model, I'd like to know if mine can be flashed:
draughthorse
thanks, ive tested it and it worksCoopervid wrote: Mon Jun 23, 2025 7:12 pmYes. It's a slim drive. The warning is meant not to flash firmware of full size drives to slim drives and vice versadraughthorse wrote: Sun Jun 22, 2025 9:55 pmare you sure... im reading the uhd drive flashing guide and it tells me specifically not to crossflash between asus and lg because it will brick my drive. is there something im missing?
davinci247
Hi all,
I have this drive model also. Does it Support 4K Blurays out of the box, or do I need to flash it? If so, where do I find the correct firmware?
OS device name: /dev/rdisk4
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E101
Serial number: SCDL117238WL
Firmware date: 2018-08-22
Highest AACS version: 76
Drive platform: RS8511
Firmware version: E101/ID26
PM sent for flashing itdavinci247 wrote: Tue Jul 08, 2025 8:59 pm Hi all,
Drive Information OS device name: /dev/rdisk4 Current profile: BD-ROM Manufacturer: ASUS Product: SBW-06D5H-U Revision: E101 Serial number: SCDL117238WL Firmware date: 2018-08-22 Bus encryption flags: 1B Highest AACS version: 76 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: E101/ID26 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
davinci247
thanks! Just got around to flashing now, worked just fine
cheers!
cheers!
