Unable to rip Thief UHD
Bguzman
Post by Bguzman »
After several attempts I keep getting the following error message.
"Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive"
sorry if this has already been discussed.
Re: Unable to rip Thief UHD
Post by SamuriHL »
Sounds like your drive isn't enabled for LibreDrive. Post the MakeMKV information for your drive.
Bguzman
Post by Bguzman »
Here is the information. My drives will work on other UHDs.
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KL7J7QF0219
Bus encryption flags: 1F
Highest AACS version: 77
Firmware version: 3.10
Bguzman
Post by Bguzman »
Sorry for the bother. I reinstalled Java and all is well.
Post by SamuriHL »
Glad you got it working. That drive definitely supports LibreDrive so you should be good.
