Unable to rip Thief UHD
Bguzman
#1 Post by Bguzman » Mon May 19, 2025 7:43 pm
After several attempts I keep getting the following error message.
"Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive"
sorry if this has already been discussed.
Re: Unable to rip Thief UHD
#2 Post by SamuriHL » Mon May 19, 2025 8:45 pm
Sounds like your drive isn't enabled for LibreDrive. Post the MakeMKV information for your drive.
Bguzman
#3 Post by Bguzman » Tue May 20, 2025 5:15 pm
Here is the information. My drives will work on other UHDs.
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KL7J7QF0219
Bus encryption flags: 1F
Highest AACS version: 77
Firmware version: 3.10
Bguzman
#4 Post by Bguzman » Tue May 20, 2025 8:27 pm
Sorry for the bother. I reinstalled Java and all is well.
#5 Post by SamuriHL » Tue May 20, 2025 9:08 pm
Glad you got it working. That drive definitely supports LibreDrive so you should be good.
