LibreDrive for Pioneer drives
I want to post this in case is it needed, since I saw the post that all Pioneers will eventually be supported I wanted to post my drive information to ensure you have the details in case it will be included for support.
Product: BD-RW BDR-S13JX
Revision: 1.05
Firmware date: 2023-08-01
Highest AACS version: 68
Firmware version: ID72
Manufacturer: Pioneer
Hopefully we are able to get this working eventually and I'll stay tuned for updates along the way.
Revision: 1.05
It will just be a matter of flashing your drive using MakeMKV's built in sdftool (or the SDFTool Flasher GUI) when the time comes.jacksans wrote: Mon May 12, 2025 11:46 pm I want to post this in case is it needed, since I saw the post that all Pioneers will eventually be supported I wanted to post my drive information to ensure you have the details in case it will be included for support.
Revision: 1.05
Excuse me, but where can I find all the updated Pioneer models compatible with Libredrive? Or could someone tell me here?
The only Pioneer models that are compatible are those with firmware pre 12/2022. All pioneer drives with firmware post 11/2022 may be able to be flashed for compatibility sometime in the future.alexbar wrote: Tue May 13, 2025 8:07 am Excuse me, but where can I find all the updated Pioneer models compatible with Libredrive? Or could someone tell me here?
You can find the drive list in the ultimate UHD guide 2025.
TylerInHiFi
Thanks! I'll get a Windows VM set up and follow the instructions you sent. I'll also work on a lens cleaning...Coopervid wrote: Wed Apr 30, 2025 8:54 amPM sent. And you should clean the laser lens regarding your reading problems.TylerInHiFi wrote: Wed Apr 30, 2025 6:03 am Hi everyone, I've got a BDR-XD07U with firmware 1.00 that doesn't seem to want to load UHD discs and is running into more frequent issues with regular blu-rays. I didn't see this firmware on the list of officially supported firmware versions, either. Here's the info panel:
Drive Information OS device name: /dev/rdisk2 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-XD07U Revision: 1.00 Serial number: RCDL004518JP Firmware date: 2017-10-30 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8D31 Firmware name: PIONEER BDR-BDS7 Firmware type: Original (unpatched) Firmware version: 1.00/ID69 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
KirbyCanvas
Yet another BDR-XD05S user. Bought my drive back in 2018 and never updated anything on it. Looking for the right firmware so I can read UHD or at least pointed in the right direction.
OS device name: F:
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: ***********
Firmware date: 2017-06-22
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
Unrestricted read speed: YesRe: LibreDrive for Pioneer drives
PM sent.KirbyCanvas wrote: Sun May 18, 2025 2:19 pm Yet another BDR-XD05S user. Bought my drive back in 2018 and never updated anything on it. Looking for the right firmware so I can read UHD or at least pointed in the right direction.
Drive Information OS device name: F: Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-XD05 Revision: 3.10 Serial number: *********** Firmware date: 2017-06-22 Bus encryption flags: 1B Highest AACS version: 68 LibreDrive Information Status: Enabled Drive platform: RS8232 Firmware name: PIONEER BDR-XD05 Firmware type: Original (unpatched) Firmware version: 3.10/ID34 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
KirbyCanvas
Many thanks! I will be trying this later and let you know. I have a 35th anniversary edition of UHF to test it on.Coopervid wrote: Tue May 20, 2025 7:03 amPM sent.KirbyCanvas wrote: Sun May 18, 2025 2:19 pm Yet another BDR-XD05S user. Bought my drive back in 2018 and never updated anything on it. Looking for the right firmware so I can read UHD or at least pointed in the right direction.
KirbyCanvas
Can confirm it worked like a charm! I am able to experience UHF in UHD!KirbyCanvas wrote: Tue May 20, 2025 12:54 pmMany thanks! I will be trying this later and let you know. I have a 35th anniversary edition of UHF to test it on.Coopervid wrote: Tue May 20, 2025 7:03 amPM sent.KirbyCanvas wrote: Sun May 18, 2025 2:19 pm Yet another BDR-XD05S user. Bought my drive back in 2018 and never updated anything on it. Looking for the right firmware so I can read UHD or at least pointed in the right direction.
Drive Information OS device name: F: Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-XD05 Revision: 3.10 Serial number: *********** Firmware date: 2017-06-22 Bus encryption flags: 1B Highest AACS version: 68 LibreDrive Information Status: Enabled Drive platform: RS8232 Firmware name: PIONEER BDR-XD05 Firmware type: Original (unpatched) Firmware version: 3.10/ID34 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes![]()
Comptech4u2
Yet another another BDR-XD05 user. If someone has the link to the appropriate firmware, I would appreciate it.
Revision: 1.21
Serial number:
Firmware date: 2014-04-02
Drive platform: RS8231
Firmware version: 1.21
Revision: 1.21
Serial number:
PM sent.Comptech4u2 wrote: Tue May 20, 2025 11:42 pm Yet another another BDR-XD05 user. If someone has the link to the appropriate firmware, I would appreciate it.
Revision: 1.21
Serial number:
Hello, since I haven't received any feedback following my message, did I forget to mention some necessary information? Thank you in advance.
PenPen wrote: Fri May 09, 2025 2:42 pm Hello, can I make my BDR-XD07 play UHD blu-rays ? Thx
Drive Information OS device name: D: Manufacturer: PIONEER Product: BD-RW BDR-XD07 Revision: 1.03 Serial number: ... Firmware date: 2020-08-20 Bus encryption flags: 13 LibreDrive Information Status: Enabled Drive platform: RS8D30 Firmware name: PIONEER BDR-BDS7 Firmware type: Original (unpatched) Firmware version: 1.03 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Comptech4u2
Thanks for the quick turnaround and donation sent.Coopervid wrote: Wed May 21, 2025 4:53 amPM sent.Comptech4u2 wrote: Tue May 20, 2025 11:42 pm Yet another another BDR-XD05 user. If someone has the link to the appropriate firmware, I would appreciate it.
Revision: 1.21
Serial number:
PM sent.PenPen wrote: Wed May 21, 2025 8:56 pm Hello, since I haven't received any feedback following my message, did I forget to mention some necessary information? Thank you in advance.
g0th1ckn1ght
Will my UHD drive eventually be able to be flashed? I have 2 of them that I would love to use.
OS device name: J:
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: BFDL006258WL
Firmware date: 2023-01-06
Highest AACS version: 77
Firmware version: ID05
Thank in advance.
OS device name: J:
Revision: 1.03
Thank in advance.
