LibreDrive for Pioneer drives
jacksans
Post by jacksans »
I want to post this in case is it needed, since I saw the post that all Pioneers will eventually be supported I wanted to post my drive information to ensure you have the details in case it will be included for support.
Product: BD-RW BDR-S13JX
Revision: 1.05
Firmware date: 2023-08-01
Highest AACS version: 68
Firmware version: ID72
Manufacturer: Pioneer
Hopefully we are able to get this working eventually and I'll stay tuned for updates along the way.
jacksans wrote:
Mon May 12, 2025 11:46 pm
Revision: 1.05
It will just be a matter of flashing your drive using MakeMKV's built in sdftool (or the SDFTool Flasher GUI) when the time comes.
alexbar
Post by alexbar »
Excuse me, but where can I find all the updated Pioneer models compatible with Libredrive? Or could someone tell me here?
alexbar wrote:
Tue May 13, 2025 8:07 am
The only Pioneer models that are compatible are those with firmware pre 12/2022. All pioneer drives with firmware post 11/2022 may be able to be flashed for compatibility sometime in the future.
You can find the drive list in the ultimate UHD guide 2025.
TylerInHiFi
Post by TylerInHiFi »
Coopervid wrote:
Wed Apr 30, 2025 8:54 am
TylerInHiFi wrote:
Wed Apr 30, 2025 6:03 am
Hi everyone, I've got a BDR-XD07U with firmware 1.00 that doesn't seem to want to load UHD discs and is running into more frequent issues with regular blu-rays. I didn't see this firmware on the list of officially supported firmware versions, either. Here's the info panel:
OS device name: /dev/rdisk2
Manufacturer: PIONEER
Product: BD-RW BDR-XD07U
Revision: 1.00
Serial number: RCDL004518JP
Firmware date: 2017-10-30
Highest AACS version: 81
Drive platform: RS8D31
Firmware version: 1.00/ID69
PM sent. And you should clean the laser lens regarding your reading problems.
Thanks! I'll get a Windows VM set up and follow the instructions you sent. I'll also work on a lens cleaning...
KirbyCanvas
Post by KirbyCanvas »
Yet another BDR-XD05S user. Bought my drive back in 2018 and never updated anything on it. Looking for the right firmware so I can read UHD or at least pointed in the right direction.
OS device name: F:
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: ***********
Firmware date: 2017-06-22
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
KirbyCanvas wrote:
Sun May 18, 2025 2:19 pm
OS device name: F:
Revision: 3.10
PM sent.
KirbyCanvas
Coopervid wrote:
Tue May 20, 2025 7:03 am
OS device name: F:
Revision: 3.10
PM sent.
Many thanks! I will be trying this later and let you know. I have a 35th anniversary edition of UHF to test it on. :)
KirbyCanvas
KirbyCanvas wrote:
Tue May 20, 2025 12:54 pm
OS device name: F:
Revision: 3.10
PM sent.
Can confirm it worked like a charm! I am able to experience UHF in UHD!
Comptech4u2
Post by Comptech4u2 »
Yet another another BDR-XD05 user. If someone has the link to the appropriate firmware, I would appreciate it.
Revision: 1.21
Serial number:
Firmware date: 2014-04-02
Drive platform: RS8231
Firmware version: 1.21
Comptech4u2 wrote:
Tue May 20, 2025 11:42 pm
Revision: 1.21
Serial number:
PM sent.
PenPen
Post by PenPen »
Hello, since I haven't received any feedback following my message, did I forget to mention some necessary information? Thank you in advance.
PenPen wrote:
Fri May 09, 2025 2:42 pm
Hello, can I make my BDR-XD07 play UHD blu-rays ? Thx
Revision: 1.03
Serial number: ...
Firmware date: 2020-08-20
Bus encryption flags: 13
Drive platform: RS8D30
Firmware version: 1.03
Comptech4u2
Coopervid wrote:
Wed May 21, 2025 4:53 am
Revision: 1.21
Serial number:
PM sent.
Thanks for the quick turnaround and donation sent.
PenPen wrote:
Wed May 21, 2025 8:56 pm
Revision: 1.03
Serial number: ...
PM sent.
g0th1ckn1ght
Post by g0th1ckn1ght »
Will my UHD drive eventually be able to be flashed? I have 2 of them that I would love to use.
OS device name: J:
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: BFDL006258WL
Firmware date: 2023-01-06
Highest AACS version: 77
Firmware version: ID05
Thank in advance.
