BDR 212V UHD Guide
Re: BDR 212V UHD Guide
#136 Post by Coopervid » Tue May 20, 2025 6:42 am
waycarwin wrote: Sat May 17, 2025 3:08 am Have two Blu-Ray Drives, one was flashed for UHD but recently stopped working, refusing ANY firmware updates. The other hasn't been modfied, but I've seen people saying it can be flashed.
The one not working is an LG WH16NS40, it won't open its door or respond to anything. It's info, as copied:
Product: BD-RE BH16NS60
Revision: BOOT
Highest AACS version: 81
The other is a Pioneer Drive, I've not pulled it out since assembling the current build so I can't say anything from the label. It works right now, but can't do UHDs yet:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.00
Serial number: ---
Firmware date: 2020-08-07
Bus encryption flags: 13
Drive platform: RS8F00
Firmware version: 1.00/ID06
PM sent for your Pioneer.
#137 Post by Coopervid » Tue May 20, 2025 6:44 am
hud55duh wrote: Sat May 17, 2025 2:55 pm Greetings. I have been looking around for the guide for BDR 212V. I know @Coopervid is helping on this topic. I wonder if Coopervid or someone else wanted to pay it forward to me that would be Awesome. Thank you. :)
hud55duh wrote: Mon May 12, 2025 5:22 am Greetings been using MKV years and finally purchased my first UHD and yes didn't work. :) Would be great to get instruction on how to flash this drive. Is this windows only solution. Thank you in advance.
Drive information:
Revision: 1.00
Highest AACS version: 77
PM sent.
#138 Post by Coopervid » Tue May 20, 2025 6:47 am
paz1200 wrote: Sat May 17, 2025 3:59 pm And another, if you wouldn't mind Coopervid. Thank you in advance.
OS device name: E:
Revision: 1.02
Serial number: *************
Firmware date: 2022-05-31
Firmware version: ID06
PM sent.
#139 Post by Coopervid » Tue May 20, 2025 6:48 am
WFAHM wrote: Sat May 17, 2025 7:12 pm Hey Coopervid, hoping you could send me a PM as well. Thanks!
OS device name: K:
Revision: 1.02
Highest AACS version: 46
PM sent.
#140 Post by Coopervid » Tue May 20, 2025 6:50 am
bluraycollector wrote: Sun May 18, 2025 7:07 pm Hi! I am also a long time user of MakeMKV and my ASUS drive is starting to give errors with reading discs. I saw the update of Pioneer drives potentially being supported in the future and took a gamble on a Pioneer BDR-212V. I have added the drive info below. Would it be okay to get the flasher for this? Thank you for your help! Also, I do have it in an enclosure and I read somewhere that the power and USB cable need to be removed afterwards. Does that mean right after flashing, I turn off the device with the power switch on the back of the enclosure, unplug the the USB cable and power cable, and then plug them back in before powering it back on?
Drive info:
Revision: 1.02
Serial number: ...
PM sent.
#141 Post by Coopervid » Tue May 20, 2025 6:53 am
JumpyGrumpy wrote: Sun May 18, 2025 8:50 pm Hello! In anticipation of resolution of the Pioneer firmware/support issues, I picked up a BDR-212V:
OS device name: /dev/sr1
Revision: 1.02
Serial number: <redacted>
Highest AACS version: 58
I've tried using it as-is with my registered MakeMKV under Linux/Fedora 42 (installed via Flatpak) and I can't get it to work with ANY discs: DVD, Blu-Ray, UHD (I didn't expect this to work). My cross-flashed LG WH16NS40 (cross flashed to WH16NS60) works fine, so I know my MakeMKV install is fine. The discs mount and are browsable through OS, and the DVD can play via VLC, so I think the drive is OK. I had the same experience with a BDR-XS07S I had briefly. It will register a disk being inserted and then just spin with "Disk Loading" forever.
This is my first Pioneer drive, so I'm not sure whether it should work out of the box with MakeMKV, or if there's some issue with it. Also, assuming that this is normal until it is LibreDrive enabled (via cross-flashing), may I have the necessary files for that, please?
Return it. It's a defective return.
#142 Post by Coopervid » Tue May 20, 2025 6:54 am
ManMower wrote: Sun May 18, 2025 11:32 pm Picked one up on Amazon...
Revision: 1.02
May I have a PM? Thanks.
PM sent.
#143 Post by Coopervid » Tue May 20, 2025 6:56 am
bingmobo wrote: Mon May 19, 2025 4:45 pm Good day all,
May I please be directed to the firmware flash procedures as well?
My discs appear to be getting disc rot and I'm trying to preserve what I can (including UHDs if possible) and hear that this BDR 212V is a possible inexpensive solution.
I have one now, but don't know where to start. Any assistance is most helpful. Thank you.
-Bing :D
Post your Makemkv info.
FeralGrizz
#144 Post by FeralGrizz » Tue May 20, 2025 12:23 pm
FeralGrizz wrote: Fri May 16, 2025 5:21 pm Just picked this same drive up. Looking to rip with it.
OS device name: F:
Revision: 1.02
Hiya Coopervid, looking for firmware as well. :D
#145 Post by Coopervid » Wed May 21, 2025 12:12 am
FeralGrizz wrote: Tue May 20, 2025 12:23 pm
OS device name: F:
Revision: 1.02
PM sent.
internetdan
#146 Post by internetdan » Thu May 22, 2025 12:59 am
Hello my LG drive is also failing as well, Coopervid can you help?
OS device name: J:
Revision: 1.02
Signals
#147 Post by Signals » Thu May 22, 2025 1:53 am
I have a new BDR-212V that needs the appropriate firmware. Here is my drive info:
OS device name: U:
Revision: 1.02
Can I please get a PM? Thank you.
#148 Post by Coopervid » Thu May 22, 2025 4:45 am
internetdan wrote: Thu May 22, 2025 12:59 am Hello my LG drive is also failing as well, Coopervid can you help?
OS device name: J:
Revision: 1.02
PM sent.
#149 Post by Coopervid » Thu May 22, 2025 4:47 am
Signals wrote: Thu May 22, 2025 1:53 am I have a new BDR-212V that needs the appropriate firmware. Here is my drive info:
OS device name: U:
Revision: 1.02
PM sent.
Richard876
#150 Post by Richard876 » Thu May 22, 2025 1:17 pm
Hi
Well, my Drive has turned up
Checked and I can read Blu-Ray, but no disk for UHD
Coopervid can you help with the update required?
Revision: 1.02
Serial number: XXXXXXXXXXXX
Highest AACS version: 65
