Re: SDFtool Flasher
Post by Billycar11 » Fri May 16, 2025 8:07 pm
XTRProf wrote: Fri May 16, 2025 7:36 am Sorry. Try to flash my second Verbatim 43888 but there is an error code message. How come?
Thanks.
Chong
Take the disc out man
Re: SDFtool Flasher
Post by MartyMcNuts » Sat May 17, 2025 12:36 am
XTRProf wrote: Fri May 16, 2025 7:04 am Sorry for this noob question. Does the firmware 1.03 MK or in fact any jail broken firmwares make the drive now region free at least for DVDs. I know blurays and UHD blurays lately no such constraint on the number of region changes that can be made limited to 5 before the drive being locked into the last done region.
Thanks for any clarification.
Chong
No, the firmware has nothing to do with the region coding. MakeMKV should take care of that when ripping anyway.
XTRProf
Re: SDFtool Flasher
Post by XTRProf » Sat May 17, 2025 5:29 am
Billycar11 wrote: Fri May 16, 2025 8:07 pm
Thanks.
Chong
Ha, didn't know. Everything in order now, sir! Now I have 2 fully jail broken Verbatim 43888 at 1.03 MK firmware version.
Thanks very much. Salute! :mrgreen:
Chong
XTRProf
Re: SDFtool Flasher
Post by XTRProf » Sat May 17, 2025 5:32 am
MartyMcNuts wrote: Sat May 17, 2025 12:36 am
Chong
Thanks and noted, man!
Chong
seatopian
Re: SDFtool Flasher
Post by seatopian » Sun May 18, 2025 6:31 pm
Hello, I just got my Archgon MD-8107S-U3-UHD, it was version 1.01, used the GUI to take it 1.03MK, then tested a disc.
Screenshot 2025-05-18 143054.png (37.47 KiB) Viewed 25084 times
No disc. Tried flashing to 1.00, no disc then too. Am I doing something wrong?
Re: SDFtool Flasher
Post by MartyMcNuts » Sun May 18, 2025 10:54 pm
seatopian wrote: Sun May 18, 2025 6:31 pm Hello, I just got my Archgon MD-8107S-U3-UHD, it was version 1.01, used the GUI to take it 1.03MK, then tested a disc.
Allow the OS to initialize the disc before opening MakeMKV.
Ensure MakeMKV has internet access as this is needed to download the UHD hashed keys.
Clean the disc with a microfiber cloth.
seatopian
Re: SDFtool Flasher
Post by seatopian » Sun May 18, 2025 11:40 pm
MartyMcNuts wrote: Sun May 18, 2025 10:54 pm
Done all three, even tried another disc from the same set.
Re: SDFtool Flasher
Post by MartyMcNuts » Mon May 19, 2025 12:34 am
seatopian wrote: Sun May 18, 2025 11:40 pm
What disc set it it? If it's GoT or LotR, these are well known as notoriously bad quality disc pressings.
Can you see the disc in windows explorer?
Does a normal BD disc work?
seatopian
Re: SDFtool Flasher
Post by seatopian » Mon May 19, 2025 4:47 am
German 4K of RoboCop.
Can't see the disc in explorer either. Normal BDs (even from the same set) work
Re: SDFtool Flasher
Post by MartyMcNuts » Mon May 19, 2025 6:03 am
seatopian wrote: Mon May 19, 2025 4:47 am German 4K of RoboCop.
If BD's work, then the laser is fine. You may need to wash the UHD disc with soapy water and dry with a microfiber cloth. I'd then let it finish air drying overnight before testing it again. It's possible the disc may be faulty. Try another UHD disc.
Also, it sounds silly but sometimes a drive just doesn't like a particular disc. It happens... This is one of the reasons why most of us have multiple drives.
seatopian
Re: SDFtool Flasher
Post by seatopian » Mon May 19, 2025 6:06 am
Gotcha. For what it's worth, I also just now tried my US 4K of Alien and it's not reading either. Will try to clean all three tomorrow! Thanks for the help.
EDIT: a little bit after i posted this, i decided to double check and now it's stalling out on regular BD discs. think i got a faulty drive.
Re: SDFtool Flasher
Post by MartyMcNuts » Mon May 19, 2025 6:20 am
seatopian wrote: Mon May 19, 2025 6:06 am Gotcha. For what it's worth, I also just now tried my US 4K of Alien and it's not reading either. Will try to clean all three tomorrow! Thanks for the help.
Yeah, possibly. Maybe return it and get something else...
disneyvader
Re: SDFtool Flasher
Post by disneyvader » Tue May 20, 2025 5:24 pm
im getting an error telling me i dont have MakeMKV installed but clearly i do what is happening here? Image https://imgur.com/a/x9ZL1iH
zittrig
Re: SDFtool Flasher
Post by zittrig » Tue May 20, 2025 5:39 pm
Is MakeMKV installed to the default location?
disneyvader
Re: SDFtool Flasher
Post by disneyvader » Wed May 21, 2025 2:29 pm
zittrig wrote: Tue May 20, 2025 5:39 pm Is MakeMKV installed to the default location?
No i installed it on a different drive than my OS
I have tried running the software from the same location I installed MakeMKV
