PM sent.staticx57 wrote: Wed Apr 23, 2025 3:07 pm Hi, first time poster here. Here is my drive:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.01
Serial number:
Firmware date: 2018-12-03
Drive platform: Pioneer RS8D30
Firmware version: ID35
Pioneer BD-RW BDR-XD07 - Troubleshooting 4kUHD discs not reading
Re: Pioneer BD-RW BDR-XD07 - Troubleshooting 4kUHD discs not reading
Sure email me that infostaticx57 wrote: Wed Apr 23, 2025 3:07 pm Hi, first time poster here. Here is my drive:
Revision: 1.01
Serial number:
Email below
Thank you, worked great!Coopervid wrote: Wed Apr 23, 2025 4:55 pmPM sent.staticx57 wrote: Wed Apr 23, 2025 3:07 pm Hi, first time poster here. Here is my drive:
Revision: 1.01
Serial number:
Hey first time poster aswell.
OS device name: /dev/sr0
Revision: 1.05
Serial number: CGDL018153WL
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 68
Firmware version: GENE
is it possible with my model aswell, thanks
Revision: 1.05
No. Your firmware is too new. You will have to wait until all newer Pioneer drives are supported. viewtopic.php?f=16&t=37848Galaxty wrote: Sat May 17, 2025 7:18 am Hey first time poster aswell.
Revision: 1.05
djmaster329
Hi everyone, I believe I've got a similar device and firmware as most people in this topic. The drive has been working perfectly for regular BD and DVDs, but if I can add the possibility to read 4k UHD disks as well that would definitely be interesting! Thanks in advance!
Revision: 1.03
Serial number: (redacted)
Firmware date: 2020-08-20
Highest AACS version: 81
Drive platform: RS8D30
Firmware version: 1.03
Revision: 1.03
PM sent.djmaster329 wrote: Sat Aug 09, 2025 3:00 pm Hi everyone, I believe I've got a similar device and firmware as most people in this topic. The drive has been working perfectly for regular BD and DVDs, but if I can add the possibility to read 4k UHD disks as well that would definitely be interesting! Thanks in advance!
Revision: 1.03
May I have help too? I've the same exact model. here's my info:Coopervid wrote: Sun Jan 26, 2025 9:41 pmPM sent.caddy99 wrote: Sun Jan 26, 2025 1:41 pm Hi Coopervid, can you please assist me with flashing my drive to Read UHD disks as well please.
OS device name: O:
Revision: 1.03
Serial number:
Revision: 1.03
Serial number: TKDL023907UC
PM sent.pelo88 wrote: Sat Aug 16, 2025 2:02 amMay I have help too? I've the same exact model. here's my info:Coopervid wrote: Sun Jan 26, 2025 9:41 pmPM sent.caddy99 wrote: Sun Jan 26, 2025 1:41 pm Hi Coopervid, can you please assist me with flashing my drive to Read UHD disks as well please.
OS device name: O:
Revision: 1.03
Serial number:
Revision: 1.03
MrGlimlach
I just got the same model also, here is my info, any help will be greatly appreciated:
Current profile: DVD-ROM
Revision: 1.03
Serial number: TLDL024540UC
Disc Information
Revision: 1.03
Disc Information
baseliners
Hi Coopervid - i'm also trying to get 4K UHD working w this disc reader. Below is my info. Can you please help? Thanks much in advance!
OS device name: /dev/rdisk4
Product: BD-RW BDR-XD08
Revision: 1.01
Serial number: CBDL300107UC
Firmware date: 2022-10-11
Highest AACS version: 26
Drive platform: RS9330
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.01
Pm sent.baseliners wrote: Sat Aug 16, 2025 5:26 pm Hi Coopervid - i'm also trying to get 4K UHD working w this disc reader. Below is my info. Can you please help? Thanks much in advance!
Drive Information OS device name: /dev/rdisk4 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-XD08 Revision: 1.01 Serial number: CBDL300107UC Firmware date: 2022-10-11 Bus encryption flags: 1B Highest AACS version: 26 LibreDrive Information Status: Enabled Drive platform: RS9330 Firmware name: PIONEER BDR-BDS8 Firmware type: Original (unpatched) Firmware version: 1.01 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
baseliners
Amazing, worked great! Sent u a donation!!
PM sent.MrGlimlach wrote: Sat Aug 16, 2025 3:23 pm I just got the same model also, here is my info, any help will be greatly appreciated:
Revision: 1.03
Disc Information
I have the same issue with the BDR-XD07UHD. None of my BR UHD 4K are readable with MakeMKV.
Can you help me ?
Informations lecteur
Nom du lecteur SE : \Device\CdRom0
Profil actuel : BD-ROM
Fabricant : PIONEER
Produit : BD-RW BDR-XD07U
Révision : 1.06
Numéro de série : ADDL002120WL
Date micrologiciel : 2024-10-09
Marqueurs d'encryptage bus : 13
Version AACS la plus haute : 76
Drive platform: Pioneer RS8D31
Firmware version: ID05
Aucun disque
Merci
Can you help me ?
Fabricant : PIONEER
Révision : 1.06
Aucun disque
Merci
