BDR 212V UHD Guide
MonkeyFarmer
Re: BDR 212V UHD Guide
Post by MonkeyFarmer » Tue May 13, 2025 12:12 am
Coopervid wrote: Wed May 07, 2025 9:50 am PM sent.
I'm a long time user of MakeMKV and have been lurking on here for years, but just created an account, so I'm unable to PM. Would it be possible to get the flasher for the 212V? I just purchased one on Amazon when the news was posted about all Pioneer drives soon being able to be flashed, so I figured it'd be worth the risk if I got one with a weird firmware version.
Anyway, I posted my details on that thread, here:
viewtopic.php?p=174492#p174492
My LG is fading so I'm hoping this will be able to handle UHD discs it was unable to rip—I lost my 4K collection when migrating to a new NAS, so I'm having to re-rip everything.
Post by Coopervid » Tue May 13, 2025 1:46 am
MonkeyFarmer wrote: Tue May 13, 2025 12:12 am
PM sent.
Chaoschimp
Post by Chaoschimp » Thu May 15, 2025 12:56 am
Just joined Pioneer bandwagon. Hoping to add UHD capability. Thanks in advance for any help. I very much appreciate your time.
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: **********
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 81
Firmware version: ID06
Post by Coopervid » Thu May 15, 2025 5:13 am
Chaoschimp wrote: Thu May 15, 2025 12:56 am Just joined Pioneer bandwagon. Hoping to add UHD capability. Thanks in advance for any help. I very much appreciate your time.
Revision: 1.02
PM sent.
FeralGrizz
Post by FeralGrizz » Fri May 16, 2025 5:21 pm
Just picked this same drive up. Looking to rip with it.
OS device name: F:
Revision: 1.02
brosef
Post by brosef » Fri May 16, 2025 11:19 pm
Would I be able to get some assistance as well? Getting some UHD failures on my WH16NS40, so I also got a BDR-212V.
OS device name: E:
Revision: 1.02
Serial number:
Highest AACS version: 61
waycarwin
Post by waycarwin » Sat May 17, 2025 3:08 am
Have two Blu-Ray Drives, one was flashed for UHD but recently stopped working, refusing ANY firmware updates. The other hasn't been modfied, but I've seen people saying it can be flashed.
The one not working is an LG WH16NS40, it won't open its door or respond to anything. It's info, as copied:
Product: BD-RE BH16NS60
Revision: BOOT
The other is a Pioneer Drive, I've not pulled it out since assembling the current build so I can't say anything from the label. It works right now, but can't do UHDs yet:
OS device name: E:
Revision: 1.00
Serial number: ---
Firmware date: 2020-08-07
Drive platform: RS8F00
Firmware version: 1.00/ID06
hud55duh
Post by hud55duh » Sat May 17, 2025 2:55 pm
Greetings. I have been looking around for the guide for BDR 212V. I know @Coopervid is helping on this topic. I wonder if Coopervid or someone else wanted to pay it forward to me that would be Awesome. Thank you. :)
hud55duh wrote: Mon May 12, 2025 5:22 am Greetings been using MKV years and finally purchased my first UHD and yes didn't work. :) Would be great to get instruction on how to flash this drive. Is this windows only solution. Thank you in advance.
Drive information:
Revision: 1.00
Highest AACS version: 77
paz1200
Post by paz1200 » Sat May 17, 2025 3:59 pm
And another, if you wouldn't mind Coopervid. Thank you in advance.
OS device name: E:
Revision: 1.02
Serial number: *************
WFAHM
Post by WFAHM » Sat May 17, 2025 7:12 pm
Hey Coopervid, hoping you could send me a PM as well. Thanks!
OS device name: K:
Revision: 1.02
Highest AACS version: 46
bluraycollector
Post by bluraycollector » Sun May 18, 2025 7:07 pm
Hi! I am also a long time user of MakeMKV and my ASUS drive is starting to give errors with reading discs. I saw the update of Pioneer drives potentially being supported in the future and took a gamble on a Pioneer BDR-212V. I have added the drive info below. Would it be okay to get the flasher for this? Thank you for your help! Also, I do have it in an enclosure and I read somewhere that the power and USB cable need to be removed afterwards. Does that mean right after flashing, I turn off the device with the power switch on the back of the enclosure, unplug the the USB cable and power cable, and then plug them back in before powering it back on?
Drive info:
Revision: 1.02
Serial number: ...
JumpyGrumpy
Post by JumpyGrumpy » Sun May 18, 2025 8:50 pm
Hello! In anticipation of resolution of the Pioneer firmware/support issues, I picked up a BDR-212V:
OS device name: /dev/sr1
Revision: 1.02
Serial number: <redacted>
Highest AACS version: 58
I've tried using it as-is with my registered MakeMKV under Linux/Fedora 42 (installed via Flatpak) and I can't get it to work with ANY discs: DVD, Blu-Ray, UHD (I didn't expect this to work). My cross-flashed LG WH16NS40 (cross flashed to WH16NS60) works fine, so I know my MakeMKV install is fine. The discs mount and are browsable through OS, and the DVD can play via VLC, so I think the drive is OK. I had the same experience with a BDR-XS07S I had briefly. It will register a disk being inserted and then just spin with "Disk Loading" forever.
This is my first Pioneer drive, so I'm not sure whether it should work out of the box with MakeMKV, or if there's some issue with it. Also, assuming that this is normal until it is LibreDrive enabled (via cross-flashing), may I have the necessary files for that, please?
ManMower
Post by ManMower » Sun May 18, 2025 11:32 pm
Picked one up on Amazon...
Revision: 1.02
May I have a PM? Thanks.
bingmobo
Post by bingmobo » Mon May 19, 2025 4:45 pm
Good day all,
May I please be directed to the firmware flash procedures as well?
My discs appear to be getting disc rot and I'm trying to preserve what I can (including UHDs if possible) and hear that this BDR 212V is a possible inexpensive solution.
I have one now, but don't know where to start. Any assistance is most helpful. Thank you.
-Bing :D
Post by Coopervid » Tue May 20, 2025 6:40 am
brosef wrote: Fri May 16, 2025 11:19 pm Would I be able to get some assistance as well? Getting some UHD failures on my WH16NS40, so I also got a BDR-212V.
OS device name: E:
Revision: 1.02
Serial number:
PM sent.
